Results 1 to 2 of 2
Thread: Misfire pids missing from available pids?? 2016 Mustang GT
    TC-1791 controller. Have a vehicle with intermittent misfire, however I can not find current and historical misfire pids per cylinder using the VCM scanner. Is my junk out of date or am i loosing my mind?
    Jan 2022
    Southern California
    466
    You just have to hunt for it in the list, and if not there, you may be screwed. There is no option in HP to record misfire on my car either, I have to use different hardware to see that.
    Apparently, from what I heard, if you find the ID #'s for them on your own and give them to HP, they will add them.
    EDIT: I retract the part about mine not able to record misfire. I found it just now. Maybe when I looked the first time it was what buttons I had, or not, clicked in the Channel Selector? So maybe play with the buttons?
    Last edited by chevota; 09-23-2024 at 09:41 PM. Reason: Brain not working properly
    '16 E550 Coupe RWD - C207.373 / M278.922 / MED17.7.3 / 722.909
