Page 3 of 3 FirstFirst 123
Results 41 to 44 of 44
Thread: VTT adjustment after going FI - need help
  1. #41
    Tuning Addict
    Jan 2015
    7,152
    This is one I did a little while back. I did install the sciap settings and resent this to the customer a while after having his tune done just because he does some seriously heavy towing with this one and needs the throttle control. It's not perfect. I do some things differently now with the torque settings and what not, but I guess the main things you want to see are there. This one does have the torque model and the variable cam timing set up to keep the moving cam in the picture. VE is also set to stay as close as possible for the moving cam.
    ~Greg Huggins~
  2. #42
    May 2023
    Kyiv, Ukraine
    75
    Thank you. Are these from the same car? The VT tables has very subtle changes in them when comparing
  3. #43
    Tuning Addict
    Jan 2015
    7,152
    Torque won't change a whole whole lot in your light throttle area with the addition of a blower, but instead in the higher airmasses and loads. The tool I use for working the torque models doesn't get them 100% accurate, but it seems to work decently with remapping things as you could see from your idle timing and everything in that regard going back close to stock. It just uses the changes to the VE table since it's a direct representation of what's changing to the efficiency of the motor to remap the models and while a blower does change the lighter load VE values a little, it doesn't change it a whole lot. If I were to make the torque model more realistic, the map side would most likely be a little flatter and come in sooner, but that can mess with throttle depending on the multipliers working in the background, so to keep the throttle operation as right as i can, especially when cam movement is involved, I just apply the same correction method to all of the map tables. Yes, you should be able to look at the vins and OS's to see the vehicle is the same. I'm not too worried about things getting copied as a lot of changes took place in the background tables that the majority of people out there can't see. Plus, there are settings in this that the owner of the truck wanted, that i wouldn't necessarily recommend doing like the fast torque exit stuff and a few others.
    ~Greg Huggins~
  4. #44
    May 2023
    Kyiv, Ukraine
    75
    Yeah, that's what I was afraid of - in my case these hard shifts felt like the torque was 40+% off and I was hoping for more difference NA/FI. Thanks for the help, I will continue this quest in spring I guess)
