Thread: Polaris Pro R with added Turbo first time setup
    Sep 2024
    Cool Polaris Pro R with added Turbo first time setup
    Hi first time on here! Looking for initial setup help for my 2022 Polaris Pro R with added turbo kit. Basically what are the first steps before starting to tune. Initial setup after adding a turbo to Polaris Pro R
    So far I have managed to connect up and read the machine and everything looks like its working.
    I have viewed the injector dynamics reference page "Injector Dynamics Data Generator"
    Also replaced the new Map sensor
    If anyone can point me in the right direction for initial setup before starting that would be great!
    Non EVAP model but I believe the standard supplied file from HP Tuners has the EVAP (any info on how to remove or turn it off would be great)
    If there is anyone who has experience with the turbo turbo pro r?
    Cheers from Downunder NZ
    Mar 2024
    42
    Good luck. There is not much sharing when it comes to the boosted side of this MG1. I am up and running with our car as well. 35-770 turbo. I found bosch 0281006076 that is a direct fit and data sheet easily available to try and rescale, but I am not sure this ecu needs it.
    Oct 2007
    Crawfordville, FL
    2,584
    Quote Originally Posted by GWProRTurbo View Post
    You should get an exact match of the file that is in your ECU.
    Eric Brooks
    HP Tuners, LLC
    Sep 2024
    All sorted Pandemic in USA and Dtech in Tauranga New Zealand. Happy days!
