Page 1 of 4 1234 LastLast
Results 1 to 20 of 63
Thread: o2 respond graph. which one looks right to you?
    08 c6. mostly stock just bank 1 is really fast switching like. jagged looking bank 2 is smooth but seems slow
    these are fairly new denso o2's if I remember right.
    any thoughts? 2nd from the bottom purple is bank 1 light blue bank 2
    Aug 2006
    5BA8
    5,473
    Bank 1 has a miss.
    EFI specialist
    email=[email protected]
    thank you. I'll try a new one
    I believe that's the easy one to change. 2 is buried and gotta remove the exhaust.
    edit, or do you mean a missfire? it feels smooth?
    Aug 2006
    5BA8
    5,473
    Quote Originally Posted by ??? View Post
    Try a new one what? There's nothing wrong with the sensor. That cylinder bank has a miss. Need to diagnose and fix the miss.
    EFI specialist
    yeah, I missed what your meant at first, I never considered it might be missing till after your said it.
    so I'm not used to searching for misses on a smooth running motor. stock cam and all. no cyl miss showing in the data. my experience with misses is they show up under low rpm high load the most, this thing doesn't show any signs that would make me think anything is wrong drivability wise.
    I gotta come up with a plan to at least find out which cyl it is. I have a temp tester, maybe I can find one tube cooler than the others.
    hmm. hate to just throw parts at it.
    Nov 2006
    North Carolina
    4,846
    I don't think that screen shot came from that log
    it's just a pic of the screen from my phone while it was idling, not an actual screen shot from reviewing the log after I took that while in the car real quick to send to a friend. I might have uploaded a different log, since i stopped and started the entire a few times while checking stuff.
    I'll check. but it seems consistent? even old logs 4 years ago with stock exhaust show it, I was looking thinking maybe a header leak in one cyl. but it was still there.
    thanks for looking. I'll fire up the laptop and double check there's a good log of it.
    Aug 2006
    5BA8
    5,473
    Post a fresh log.
    EFI specialist
    started log from a cold start but then realized i didn't add missfire data, stopped log and added. did not shut down the car. so 2nd log is the same start.
    got quick video of it idling too, incase someone hears something i don't
    Aug 2006
    5BA8
    5,473
    100% that's a miss on that bank.
    EFI specialist
    OK, thanks. I'll dig into it.
    any guess on a cyl from that?
    maybe I'll just do. plugs anyway, even thou pretty new and change everything left to right while it's apart.
    you think it's worth doing a compression test?
    Aug 2006
    5BA8
    5,473
    It depends on what's been done to the vehicle. If you've recently done anything with the plugs and/or wires 100% it's installer error. Either cracked plug or a plug wire not snapped on tight enough.
    EFI specialist
    Nov 2006
    North Carolina
    4,846
    I'm not seeing a miss really.
    Right click both o2 sensors in the channel list and make sure both are polling at the same rate. Also check the heater fuse just in case.
    Aug 2006
    5BA8
    5,473
    Regardless of sample rate that's a misfire on bank 1.
    EFI specialist
    Nov 2006
    North Carolina
    4,846
    I disagree.. but that is what is nice. We will still be friends
    lol
    Senior Tuner Cringer's Avatar
    Aug 2021
    Somewhere smoothing your VVE table
    1,127
    Export log to CSV, no interpolation...both O2 channels are polling at the same frequency and have timestamps that average .033ms (about 30 Hz)
    <<< A standard approach will give you standard results >>>
    My Free Tuning Software:
    VVE Assistant [update for v1.5]
    MAF Assistant
    EOIT Assistant
    Oct 2014
    Moscow, Russia
    320
    Second.
    I'll bet for a faulty injector.
    2011 Cadillac Escalade L94 w/LS3 valves and valve springs
    Nov 2006
    North Carolina
    4,846
    Quote Originally Posted by Cringer View Post
    I'm not sure that will positively ID that.
    There was a HPT version or something where one bank o2's were set to default poll much faster than the other side. I wanted to make sure that wasn't the issue here.
    how do I check that?
    I found a log all the way back from 2017 and that side was still jagged.
    not that it couldn't be an injector or something too
