Results 1 to 8 of 8
Thread: engine diagnostic tab missing DTC codes 1999 Dakota
    Mar 2024
    16
    Trying to tune out the rear O2 sensors on my 99 Dakota R/T. I have all available DTC disabled, but it will still pop Bank 1 sensor 2 and bank 1 sensors 3 heater circuit malfuction P0141 and P0145, because those DTC dont show up in HPtuners. is there a way I can get those DTC to show up so I can disable them?
    Banned
    Jan 2022
    fountain valley
    2,379
    Leave the wires for rear sensor plugged in
    Unscrew the sensor and hang it under your truck
    Put a plug in the hole
    May 2024
    10
    -Try going Engine ; Fuel ; Oxygen Sensor the disable heater .
    But it will probably will turn off Sensor 1 heater as well
    I found that in an older post .
    -On my side , I'm looking to turn off those O2 sensor (sensor 2)codes but the line under DTC is Greyed out I can't select disable
    A friend and I are swapping a 5.9 in a '76 Dodge Aspen Thanks .
    Advanced Tuner Stoopalini's Avatar
    Nov 2023
    Central Texas
    417
    Have you tried taking the HP Tuners emissions training class to gain access to emission settings?
    2023 Dodge Durango R/T (5.7L) with Tow & Go Package (build thread)
    Gen 5x Whipple 3.0L Supercharger
    Smooth Boost Electronic Boost Controller
    SRT 392 Air Intake Conversion
    92mm Hellcat Throttle Body
    Mighty Mouse Mild SRT Catch Can Setup
    May 2024
    10
    I did , would this be a cookie on my computer or just me login in HP tuner would work ?
    I might have done it on my laptop . This moment I am on home desktop .
    Thank you so much , I will double check .
    Banned
    Jan 2022
    fountain valley
    2,379
    What I got my new computer I emailed the parameter access file to myself
    Mar 2024
    16
    Quote Originally Posted by RoadBoss2 View Post
    It's already set to disabled
    Mar 2024
    16
    Quote Originally Posted by LilSick View Post
    There is no hole in the exhaust, and this doeent fix the issue with the missing DTC in the editor
