Page 2 of 2 FirstFirst 12
Results 21 to 39 of 39
Thread: 21 ecoboost 3.0
  1. #21
    Apr 2008
    New Olreans
    33
    Quote Originally Posted by 04silverado6.0 View Post
    I will try those changes. I have a c10 on the rollers so no time to play with the ford for a couple days.
    Any updates?
    2005 a4 GTO
    403 iron motor, CNC LS9 heads, LS3 intake. Custom cam, APS twin turbo with VSracing 6766 oil-less turbos, Built 4L80e, 8.8, 3.31 gear, Fuse Performance E85r, 1111/1245 @22lbs unlocked
    2018 ZL1 A10, Magnuson 2650, 103TB, 780rwhp/790tq stock cam. Sold
    2020 Ford Explorer ST, FENFabrication Ford Explorer ST High Flow Air Intake V2, CVF Stainless Steel Catted Downpipes, Ford Explorer ST Steeda intercooler, MPV12
  2. #22
    Senior Tuner 04silverado6.0's Avatar
    Sep 2021
    Kentucky
    1,724
    Ive made a couple changes since i last posted. Thing is running awesome but i havent got a chance to log anything.
  3. #23
    Sep 2021
    Kentucky
    1,724
    Here is the latest file. Going to get a intercooler upgrade and see where its at then. For sure satisfied.
  4. #24
    Apr 2008
    New Olreans
    33
    thanks, I'm trying to learn about tuning a ford. I'm coming from GM lsx platforms
    2005 a4 GTO
  5. #25
    Sep 2021
    Kentucky
    1,724
    Any transmission changes ive done has caused a rough shift even with small changes. Stock it has a pretty dang firm shift already. I guess the torque based control is keeping up?
  6. #26
    Oct 2024
    UT
    36
    Have checked the fluid level of the trans? The come low from the factory..
  7. #27
    Sep 2021
    Kentucky
    1,724
    I have not checked the fluid level. It is under warranty by the dealer which is doing all servicing so im hoping they are checking things.
  8. #28
    Oct 2024
    UT
    36
    Honestly, they don't check the levels, if they do service it, they put back the same amount they take out..
  9. #29
    Mar 2024
    Wisconsin
    23
    Try this out.
    You can still request more fuel, down to .73-.77 lambda. With these nanos, leaving spark pretty stock and just upping and refining boost has given me the best results.
    With the newer Fords, remember to always reset adaptives and let the car idle, drive it normally for 10-15 minutes, and ideally let the OAR/KOM reach the ideal value for spark tables after each flash. That value weights other tables as well.
    Try these channels out, and update us with a log. I'm curious to see the results and your thoughts. There's two turbo shift timer's I can't find on your OSID, so it may not be 100%, but the changes are so subtle, it will be fine regardless. With the 10r's, you need to lightly adjust multiple tables at once to really get it to shift right.
    tune 14 - Try This.hpt Main Ford Channels.Channels.xml
  10. #30
    Sep 2021
    Kentucky
    1,724
    Thanks, i finally got to look at the file. Not sure when ill have time to play with it more.
  11. #31
    Sep 2021
    Kentucky
    1,724
    Quote Originally Posted by jakevandee View Post
    Try this out.
    I used some of your tables and edited some on my own, thing is shifting awesome and consistent.
  12. #32
    Can you post your latest revision?
  13. #33
    Mar 2024
    Wisconsin
    23
    You should really consider running an E blend for a fun weekend tune. It would be fun haha.
    I'm happy to help more if you post a log. If you ever run into a snag with the car, feel free to pm or message on here as well.
  14. #34
    Sep 2021
    Kentucky
    1,724
    I appreciate the help. Pretty satisfied with it for now. I give it a whiff of e one cool night it definitely picked up from a very slight amount. It will need a intercooler upgrade before spring comes back around.
  15. #35
    Mar 2024
    Wisconsin
    23
    No problem. Let me know if you need/want anything else.
  16. #36
    Apr 2008
    New Olreans
    33
    could you share your latest tune? interested in the last changes.
    2005 a4 GTO
  17. #37
    Sep 2021
    Kentucky
    1,724
    Here is the latest file. Id like to get a little more psi on the tcc. Other than that it is awesome.
  18. #38
    Any updates on how it's doing?
  19. #39
    Sep 2021
    Kentucky
    1,724
    Very satisfied with the tune. Just been putting miles on it lately. No new adjustments.
