Results 1 to 15 of 15
Thread: SOIT & EOIT Stock Motor
    Jan 2014
    SoCal
    1,846
    Question SOIT & EOIT Stock Motor
    Have a E92A, ECM, GM SIDI 2017 Tahoe 5.3 stock vehicle. Had a long term mis fires from lack of maintenance in my opinion. Melted the cats. Cats got hollowed out and I was going to be doing a trans (6L80e) tune and some VERY minor spark timing, PE, and a some DTC stuff obviously. Anyways they are complaining of the idle fuel smell. No kidding right? Have done many Gen 3 and Gen 4 EOIT adjustments for this will GREAT success but Gen 5? Yikes. Not even sure where to start. Not looking for a miracle just a reduction in the smell or where to start. Cats here in Kalifornia are double to triple the cost of any other state to purchase and they are stamped. If you have aftermarkets without the stamps you won't pass the smog and no company will mail these from out of state. Any help will be greatly appreciated.
    JAMES 2017 TAHOE E92A COMPLETE STOCK TUNE.hpt
    Senior Tuner 04silverado6.0's Avatar
    Sep 2021
    Kentucky
    1,742
    You can try this and see how it goes. Should be spraying much closer to tdc.
    Jan 2014
    SoCal
    1,846
    Quote Originally Posted by 04silverado6.0 View Post
    Thank you. I will give it a go. Vehicle should be here on Friday. I'll let you know after a test drive.
    May 2003
    South FL
    1,573
    No amount of SOI adjustments will do away with the smell when you guy the cats.
    [email protected]
    snackbartuning.com
    Owner/GM Calibrator
    E85 will clean up the smell better than fudging with SOI.
    Sep 2021
    Kentucky
    1,742
    Any updates?
    Apr 2023
    17
    I was gonna say… you have no cats, it’s gonna stink like it’s 1974. Maybe try to get some used cats?
    Aug 2009
    Calibrating
    3,409
    I get sick of hearing these big cam/ no cat setups complain about smell… it’s part of it
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen5 Viper
    Ultima RS with C8 drivetrain
    Aug 2006
    5BA8
    5,289
    Quote Originally Posted by TheMechanic View Post
    I'm not sure I get it. If you have NO cats, how are you going to pass emissions in Komifornia? I get that you need OE, but it sounds like you're trying to justify not having cats because they're expensive and then you mention the aftermarkets not passing?
    EFI specialist
    email=[email protected]
    May 2003
    South FL
    1,573
    It seems like he wants to try and solve it with a tune that adjusts SOI/EOI to reduce the smell and since the shell of the OEM cats are in place, it would hypothetically pass. But we all know the Catalyst Test will be set to fail or not ready and flashing the ECU won't help because California now does plug in emissions where they read if the ECU was altered. And no movement of the SOI is going to reduce the smell without cats. That trick is only minimally useful on big cam stuff.
    Sounds like the answer is to drive to a neighboring state and have cats installed. Truck owner chose to live in California, now deal with the ridiculous government laws and prices.
    [email protected]
    snackbartuning.com
    Owner/GM Calibrator
    Aug 2006
    5BA8
    5,289
    Ah, totally overlooked the "gutted" cats and was assuming they were removed.
    I agree, it would pass the visual but not the monitor check or the sniffer.
    EFI specialist
    Nov 2006
    North Carolina
    4,658
    It doesn't make any sense to take cats off. I've seen 1-2 rwhp on 500 rwhp NA builds. less than 10 rwhp on some big supercharged builds. The exhaust tone is better, no stink, no hassle
    I understand the cost.. but at a certain point you are spending more trying to make it work.
    Aug 2006
    5BA8
    5,289
    ^^^ Agree. I've put cats on, and recommended other people put cats on older, swap cars that really can get away with not having them.
    When you take your wife out in your 200K C1 or C2 LS swapped Corvette and she gets out smelling like fumes, well, enough of that shit. We need to fix it or she's not going out on cruise night.
    EFI specialist
    Nov 2006
    North Carolina
    4,658
    Now lets talk about open element valve cover breathers and the smell that sticks to your clothes/hair. lol
    Tuning Addict
    Jan 2015
    7,172
    No, No, No How about all of the oil vapor coming out from under the hood or the very unlucky few that actually caught on fire because of the oil dripping onto the manifolds. I have swap customer send photo's for these reasons. They're a must go on gen V's if still using any of the factory breather configuration. I've even gone as far as having some running blow through setups route the breather hoses from the crankcases to catch can"s" and then the blower or turbo inlets just like factory diesel setups after leaving. Customers are happier for it as the vapor is no longer there and getting on everything. Just may require more maf cleanings is all.
    ~Greg Huggins~
