Page 3 of 7 FirstFirst 1234567 LastLast
Results 41 to 60 of 128
Thread: How is delivered torque calculated in a gen3?
  1. #41
    Banned
    Mar 2022
    Indiana
    4,289
    No need. You can zoom in on spots and log file>export>visible range.
  2. #42
    Oct 2014
    Seattle
    145
    This what you mean? I don't seem to have "visible range" as an option on this older version.
  3. #43
    Nov 2017
    2,801
    I don't think this is a file size problem. The older scanner and newer scanner files are not compatible, at least not 100%. They changed things when they added in the ability to add markers. But I'm not 100% sure on which way causes problems or if neither is compatible with the other. But I have both versions available on different laptops.
  4. #44
    Oct 2014
    Seattle
    145
    Quote Originally Posted by GBull View Post
    Give this a try
    This works old and new, half the length.
  5. #45
    Oct 2014
    Seattle
    145
    I figured. If airflow isn't right then that'll put spark in the wrong spot on the cylair axis. Clear LTFT's and try again with this.
    On the LM1 what formula are you using? LM1 custom isn't consistent with voltage.
    Volts/1 + 0. set against a linear graph 0-5 by 0-5 volts.
  6. #46
    Oct 2014
    Seattle
    145
    shorter file size seems to have done it...
  7. #47
    Nov 2017
    2,801
    Volts/1+ 0 = Volts
  8. #48
    Oct 2014
    Seattle
    145
    Yes, SiriusC1024 was inquiring on the formula used on my LM1 custom volts input. apparently its the voltage read by the bosch wideband. 0-5. I think he felt it didn't represent correctly..?
  9. #49
    Banned
    Mar 2022
    Indiana
    4,289
    Ok here's next. Log Dynamic Airflow, EQ Commanded, LTIT, and Idle Adapt (STIT).
  10. #50
    Oct 2014
    Seattle
    145
  11. #51
    Oct 2014
    Seattle
    145
    Running pretty darn good.. First driving scan threw in some retard, however the second one did not. I stood on the brakes and let it somewhat slowly rev to 5000+ and no retard
  12. #52
    Banned
    Mar 2022
    Indiana
    4,289
    Tire size, plug type, flat or dished pistons?
  13. #53
    Oct 2014
    Seattle
    145
    NGK TR6IX iridium. Wiseco K0421X1 -9cc dish 10.35:1. Tire is 29.75" tall, 255 mm wide. Stock in all aspects.
    66cc combustion chamber (AFR 205's)
    I put about 90 miles on it today and it ran smooth and crisp.
    I can't thank you enough for what you've done.
  14. #54
    Banned
    Mar 2022
    Indiana
    4,289
    Oh no problem. Still needs some work, though.
  15. #55
    Oct 2014
    Seattle
    145
    With a running temp of 205-208 degrees F, do you think I should get a 180 thermo and bring that temp to the 198-200 range?
    Finally transcribed all changes, Logging next...
    Wondering, why does your post count not change?
  16. #56
    Banned
    Mar 2022
    Indiana
    4,289
    A little hot, but within the normal range of the 187 thermostat. A 180 certainly wouldn't hurt. Just don't get a 160. Recommend Motorad.
    Trans cooler is in front of the radiator. Some of the heat can be mitigated with lockup settings, which will be on the next tune (among other changes pending log).
    Post count updates across the site. It's not locked to the specific post.
    Thanks for the +rep!
  17. #57
    Oct 2014
    Seattle
    145
    Even better! Hard to test on wet roads..
    I got the cruise control affect 1200-1500 rpms no throttle. I did a log and histogram with Throttle cracker, with the understanding this might be why..maybe...
    No sign of knock!!
    I have done very precise mileage checks with this new engine, I'm looking forward to doing another. Cruise control at 60, precise route, 16mpg.
  18. #58
    Banned
    Mar 2022
    Indiana
    4,289
    You're right about throttle cracker.
    There's something weird going on during deep decel that I'd like to clear up.
  19. #59
    Oct 2014
    Seattle
    145
    Finished all my transcribing. You have been shaking the junk out of all sorts of corners of my tune which is AMAZING. A couple changes I made that could be in error are one, Closed Loop Prop Base vs Airflow Mode, I multiplied the table by .8. Two, Closed Loop Integrator Delay vs Airflow Mode, I multiplied the table by 1.25. And as I said in one of my early posts, I desensitized my knock sensors, Tip in TPS, Tip in RPM, and vs RPM vs Cyl. I raised these numbers by 10%. I researched this stuff quite a bit before doing but its still easy to be wrong..
    Thanks!!
  20. #60
    Oct 2014
    Seattle
    145
    Nice trans tune! Ok, cruise control affect is only tiny and I need a chance to really drive a little to say if it needs any change at all.
    Heavy knock retard this go round. I did 4 logs to see if it was repeatable-I have felt in the past that knock could not be reliably predicted hence the desensitizing of the knock sensors. It didn't knock last time at all, just strange...
    Anyway all logs had lots of timing pulled. I didn't hear any knock, but I drove a firetruck for thirty two years so the ears aren't original equipment quality.
    One scan didn't record past 2800 rpm-I seem to need to close and restart my scanner and this is fixed... I think that one is number 10.
    Hope you are having a good weekend.
