Results 1 to 15 of 15
Thread: My first coyote ghost tune failed
    Apr 2023
    6
    This is my first attempt to tune my nephew's truck.... cannot get it to chop...i used map point #8.... anyone willing to look?
    Mar 2017
    Georgia
    10
    Sent pm
    Mar 2017
    Georgia
    10
    Ttt
    Mar 2017
    Georgia
    10
    Help anyone?
    Sep 2022
    Clearwater FL
    450
    adjust 38180 and see what it does.
    Jun 2011
    Cyprus to Worldwide
    85
    Original file to see what you did exactly?
    Simple... Successful... Intelligent...
    Sep 2022
    Clearwater FL
    450
    Quote Originally Posted by skythunder83 View Post
    He set a few values under OS to command MP8 but tables 38180 is limiting him.
    Jun 2011
    Cyprus to Worldwide
    85
    I see that but I'm still thinking how/why he did what he did, using MP8 was based on what? usually he should start with datalog then target his MP point then adjust it, not sure if that what he did so far
    Apr 2023
    6
    Heres the oem tune
    Mar 2017
    Georgia
    10
    Didn't change anything. This is a gen1 obviously . Is there another parameter that needs to be sent? If I log the idle, it's using a percentage off of all 14
    Mar 2017
    Georgia
    10
    I chose 11 map point Because of the -30? on intake. Still no chop is a generation one able to have the Ghost cam ?
    Sep 2022
    Clearwater FL
    450
    Post the log, you can try changing the 150, 200, 220 cells on the 450 rpm range in Optimal Stability to 6 to see if maybe that's the cause.
    Also under 38169 you have OS set to .3 load on your idle cell 750 rpm. I doubt youre reaching .3 load at idle. Log VCT Schedule and post it. Im wondering if its idling in Fuel economy mode.
    Jun 2011
    Cyprus to Worldwide
    85
    I checked the stock vs your tune, your target is Ghost cam right? but I don't see modification related to that, first thing you need to do is log weight maps point where the car idle well, then adjust that one how much you want it to chop. Someone here made video for that but I have to tell you if you don't think just copy stuff it won't work well, it's all related to your car and what mod on it. https://www.youtube.com/watch?v=xqWFb1pcHwk.
    next for pop you just need to know where and when you want it to pop then drop spark there much you need it to pop strong
    Mar 2018
    451
    Just search for a boss red key tune and copy the track settings. It will chop just fine and be OEM safe.
    Feb 2017
    2
    This got me to the promised land. One of the guys on here made this.
    https://youtu.be/xqWFb1pcHwk
