Results 1 to 14 of 14
Thread: Tsp stg 2 cam & mds delete first start up help!!
    Oct 2024
    4
    Question Tsp stg 2 cam & mds delete first start up help!!
    Hi Everyone
    As the title suggests i have torn down my Ram 1500 5.7 hemi, new lifters, valves, oil pump, cam phaser locked and stage 2 TSP cam, I will have it back together this weekend, BUT can I turn it over without any PCM modifications or will it damage my engine? I guess I will need to adjust the idle, but any pointers or don't even crank it over?
    Thanks in advance!
    https://forum.hptuners.com/images/smilies/hi.gif
    Tuner MadhousePerformance's Avatar
    Dec 2018
    Florida
    65
    You can turn it over and start it it will be pissed off but should run a few seconds. i would suggest turning the engine over on a relay jumper so you can get oil from the bottom to the top of the engine. That way when you do start it it wont make as much noise. When your ready load in stock file and ask for help some not all but some will not ask you for money to help you on your tune.
    Oct 2024
    4
    Quote Originally Posted by MadhousePerformance View Post
    I appreciate you coming back to me I'm just looking for help and have no problem paying for good sound advice/help, I believe you can hold your foot flat to the floor to turn it over not start to get the oil pressure up, its just the air ratio idle etc afterwards, im confused on.
    Dec 2018
    Florida
    65
    your correct its sometyhing ive seen others do but i like the relay way since it wont put fuel in the cylinder and that also cuts spark. but yead when its started you got some help
    Oct 2024
    4
    ok so i got her started but she doesn't idle for long and sounds like the throttle body is trying to correct, she then stalls, I have to give it some gas to get her going again, I will read the stock file tonight, but I'm going in blind to be honest, I am not building this for a track, just need it to be reliable and punchy for the road/off road. Thanks in Advance!
    Banned
    Jan 2022
    fountain valley
    2,379
    could you email me the oem read and the file that is in it right now?
    thx
    Oct 2024
    4
    LIL, sent!
    thanks.
    Dec 2024
    1
    Did you end up getting it dialed in or got someone to tune it? I have the same setup and am looking for a base tune.
    Advanced Tuner N2speed's Avatar
    Mar 2021
    Pompano Beach FL
    473
    Quote Originally Posted by Tymrow View Post
    I can help [email protected]
    www.n2speed.com
    [email protected]
    Dodge And GM Tuning Support
    Diablosport CMR | HP Tuners
    Quote Originally Posted by KILLSWITCH View Post
    LIL, sent!
    thanks.
    Hello!
    Could you share the tune here?
    Thank you!
    Dec 2024
    2
    I?m need help with my 2013 dodge charger rt 5.7. I put a tsp chopacabra cam with mds delete and a wideband and long tube headers and cold air intake. Now she won?t idle and I haft to give her gas to start. I?m new to hp tuners and really need some help on tuning.
    Banned
    Jan 2022
    fountain valley
    2,379
    both chris and i have our emails listed above
    here it is again
    Aug 2021
    Indianapolis Area
    455
    Quote Originally Posted by Jarhead1985 View Post
    DO you have a tune and log to share?
    DodgeBoy.
    Email / Remote Tune: [email protected]
    Dec 2024
    2
    I have the stock tune saved
