Results 1 to 18 of 18
Thread: Oscillating Idle when cold from 93 to 140 deg ECT
    May 2008
    Wichita, Kansas
    177
    2000 Corvette with LS3 swap (Still using LS1 sensors). Starts and idles fine till about 93 ECT, then RPMs start to go up and down, it does this till about 140 ECT then smooths out and idles great. I dont think its fuel as its a dead set 14.6 at hot idle open loop, could it be proportional or integral idle?. Scanner and tune posted below.
    2000 FRC Corvette with LS3 Swap
    Aug 2006
    5BA8
    5,476
    Don't touch the idle adaptives.
    First thing is, double check your injector data.
    Second, apply the 1 bar COS to get off the secondary VE table.
    But the root cause is WAY TOO MUCH idle timing, and not aggressive enough over/under shoot.
    EFI specialist
    email=[email protected]
    Nov 2006
    North Carolina
    4,859
    I agree too much timing at idle.
    Shoot to center the idle around 18 degrees. You want to be able to go up in timing to save an idle dip and lower to pull an idle down. This is sitting in the high 20's at idle which leaves no room to go but down.
    The VE doesn't look proper for this cam/setup.
    Put the IAC setups vs effective area back to stock. There are no IAC steps on this setup but I'm fairly sure it still references that table for the ETC scalar.
    May 2008
    Wichita, Kansas
    177
    Appreciate the info guys, that fixed the issue. Went to 1 bar SD as well. She does dip about 100 RPM below set point when coming off the throttle from higher rpm but it recovers quickly.
    Nov 2006
    North Carolina
    4,859
    Quote Originally Posted by Ls1c5vette View Post
    The whole tune is going to have to come together. There won't be one little fix here or there.
    Banned
    Mar 2022
    Indiana
    4,289
    He's not too far off. Better VE, a little touch on throttle cracker and follower...
    May 2008
    Wichita, Kansas
    177
    Any idea what I could adjust to get rid of small bucking under light load from 1400-1600rpm? Fueling is spot on and I?ve tried different timing points in the vcm scanner (20, 25 and 28 degrees) but it still does it. I?ve also tried to zero out the TC table and it still does it.
    Aug 2006
    5BA8
    5,476
    Put a stock camshaft in it. You didn't mention cam specs but I'd bet it's a GMPP LS3 crate motor with a lumpy cam. If you want stock driveability put a stock cam in it.
    EFI specialist
    May 2008
    Wichita, Kansas
    177
    It has a small texas speed stage 1 cam in it. They claim it drives like stock and I have to agree it does, minus the stupid bucking 1400-1600
    Banned
    Mar 2022
    Indiana
    4,289
    Disable spark smoothing.
    Nov 2006
    North Carolina
    4,859
    what are the actual specs and I'll tell you if it's normal or not.
    A lot of issues like this will resolve themselves after the tune comes into shape. So if the fueling/ve or timing is wonky you'll get bucking. It can also be 02 sensor delay/integral induced.
    Aug 2006
    5BA8
    5,476
    Agreed that is typically the fix if it's still enabled.
    EFI specialist
    May 2008
    Wichita, Kansas
    177
    225/236 .629"/615" 114 LSA, 109 ICL. Ill try to disable spark smoothing
    Jan 2015
    Arizona
    1,291
    It has a small cam in it.
    225/236 .629"/615" .
    "small cam"
    Banned
    Mar 2022
    Indiana
    4,289
    I re-read your original problem statement. OLSD tuned. It's still in CL STFT. Look at what the fuel trims are doing. 10% rich. Tune VE with the narrowbands up to 85kPa. The O2's are switching great in the log. No need for OL, which is an assumption people make. Tune VE. It's very much a rough draft.
    With that large cam I'd recommend EOIT adjustment.
    BRAF need adjusted, as STIT+LTIT is showing a lot of air being added.
    Lower idle spark.
    Then there's the other things mentioned previously that'll help. Really, there's a lot more to be done.
    Nov 2006
    North Carolina
    4,859
    That should be easy to tune all the buck out except light/ zero pedal situations in like parking lots, low speed.
    May 2008
    Wichita, Kansas
    177
    Lower idle spark.
    Thats a old log file, BRAF is inline now (+/- .75) and VE is spot on as well (fuel trims 2%), idle spark is now at 20. I played with the excel sheets found online and got a true normal EIOT of 6.2 so for now I split the difference from the 5.55 and made it 5.80 to see how it goes. If I should just run the 6.2 as its calls for in the sheet then please let me know. Appreciate all the help thus far.
    May 2008
    Wichita, Kansas
    177
    Ok, I went with 6.10 on the EOIT, massive difference, lots more low end torque starting out from a stop and the smell of raw fuel is gone. Wish I would have tuned this table to begin with. Bucking at 1400-1600 is 85% gone.
