2022 f650
Hey there, I have a 2022 F650 the VIN says its a 2022 but the build date says 03/21 either way I am looking for pointers of the correct direction to either 1 remove the speed limiter or increase it to at least 90, when running the interstate its hard to pass by a truck that's regulated to 75/80 mph Or a tune or point me in the direction of a tune. I was thinking about a commander but thought I would ask here first. It has OBD2 port and a 9 round pin DLC
The stock 22 ECM you are limited on what you can do. If you ECM swap, you can remove the limiter. It's an expensive option for just making it go faster but that is about your only option. You cannot do anything with the 22 ECM using HPT. Even with the Avtokomander you are limited.
