looking for any useful advice on my tune, ever since i upgraded to lt1 injectors from stock l83 I've had an issue where my cam isn't quite idling like it used to. drives and idles fine but seems like its fighting itself (hardly chops and sounds like its stumbling or almost missing), im also looking for direction on how to properly get torque management to function without overly pulling timing and making the "pop" noise during shifts. any help is much appreciated!
mod list -
speed engineering long tubes
s&b cold air
jose zambrano 535 low side
lt4 head gaskets
gpi stg3 high lift truck cam +32 fuel lobe
arp headstuds
stock heads with .660 valve springs and che trunions
circle d 258mm triple disc 3600 stall
johnson 2110r drop in lifters
