Results 1 to 7 of 7
Thread: Cm2450 help
    Mar 2021
    2
    Cm2450 help
    Having an issue with a 22 cummins swapped to the tuneable cm240 ecms. Truck was previously tuned by someone else and had some issues so I tried to flash a new file with efi and truck would start and die. Tried a few different files and same issue until truck ended up just not cranking at all. Found out the truck was flashed with hp originally so ended up finding the original tune file as well so I flashed that file in and having the same issue no crank no start.... no codes anywhere I can see with alphaobd. Never fails a flash and can communicate with the ecm completely lost with this....
    Nov 2023
    n/a
    78
    sounds like the secrurity system is shutting it down. thats exactly what they do if the vin or antitheft codes are mismatch , scan the bcm and see if it has codes. it will set codes in bcm if antitheft is shutting it down
    Mar 2021
    2
    No codes in the bcm at all on alphaobd
    Advanced Tuner omega_5's Avatar
    Aug 2005
    Maidstone, SK
    484
    Quote Originally Posted by jcosta103 View Post
    Was the HPT file the one that was originally pulled from the truck? Or just one that matches?
    Aug 2023
    canada
    91
    do you have the original pcm?? powerstrokecustoms can help you with everything you need and with using the original pcm.
    Aug 2005
    Maidstone, SK
    484
    Quote Originally Posted by dieselpitstop View Post
    Jebus eff dude. Stop pedaling your hack jobs on here.
    The guy is asking for help. Either help the guy or bugger off.
    Aug 2023
    canada
    91
    hp tuners is horrible with tuning the 19 plus ecu's.. the best way to tune those is with calterm and nexiq.
