Results 1 to 15 of 15
Thread: General fueling question for cold starts
    Jun 2022
    Canada
    102
    Generally speaking what tables have the biggest effect on cold start fueling? Before the O2's kick in and I suppose after as well. FA cold tables or the ECT multiplier and factor tables? There are numerous other things that will affect the fueling but what are the usual places to start?
    usually the ones labeled startup or ones with ECT, which is engine coolant temp which the table will use engine coolant temp to define one axis of the table
    Only thing I've ever done was mess with table 34000 Engine->Fuel->General->Startup Base
    Jun 2022
    Canada
    102
    Ive used that as well but it I assume that table is only while cranking for the most part.
    Dec 2024
    Southern Utah
    3
    Depending on the ECU Crank fuel is normally the start place or as mentioned ECT tables
    Quote Originally Posted by StupidJeep View Post
    Oh, so you're looking for warmup fuel not starting fuel?
    Jun 2022
    Canada
    102
    Quote Originally Posted by Chubby Racer View Post
    Yes sorry I guess that would be a more accurate description.
    I guess follow up question would be when does it use the FA cold table vs any of the ECT VE multi and factor tables? The both seem like they do the same thing kinda...
    Nov 2019
    316
    Check out and log the "burn fraction inverse" parameter
    Banned
    Jan 2022
    fountain valley
    2,379
    which controller do you have?
    Jun 2022
    Canada
    102
    Ngc4...
    Jun 2022
    Canada
    102
    Quote Originally Posted by HaasExp View Post
    Pretty sure I don't have that parameter in the NGC4
    Banned
    Jan 2022
    fountain valley
    2,379
    you should
    fuel > transients
    Jun 2022
    Canada
    102
    Son of a bitch you are correct! Ill add to the log and see what I get. Then figure out what to do with that information
    Banned
    Jan 2022
    fountain valley
    2,379
    just because there is a table in the controller does not mean scanner can log pertinent data for said table
    Jun 2022
    Canada
    102
    Quote Originally Posted by LilSick View Post
    So here is where Im at...it is logging something for burn fraction. Dont know what to do with it even if it telling me something useful. And there isn't a table in NGC 4 that lets me change anything anyway. Attached is latest log of a cold start with a short drive home from work. real rich at first but cleans up as it gets warmer... VE doesnt look the best in this log but the longer it runs the better it gets with the exception of the anomalies of being real rich at start up. Once warm it seems to run and drive pretty good. I just want to get the cold fuel under control and tame the rpm swings at he start then I think Im good...
    current short drive.hpl
    Dec 16 cld start fat.hpt
