Results 1 to 6 of 6
Thread: 2009 Challenger 6.1 cam idle help needed
    Hey all,
    I have a 2009 Challenger 6.1 with a fairly mild cam (223/235) that I'm wrestling with idle tuning. I need some assistance if possible
    When the motor is cold, it's not too bad, but as it warms up, it seems to get worse. It will surge while trying to hold steady idle and then dies when it comes back down from a blip of the throttle. It's not too bad when cold, but it gets much worse as it comes to temp.
    I've looked at a lot of the how-to articles here but can't seem to get anything that makes a difference in the positive direction. I've been resetting adaptives each time a change is made.
    Below is a log and tune file if I can get some pointers.
    Thanks again
    TUNE_CL_23.hpt
    idle-die.hpl
    Banned
    Jan 2022
    fountain valley
    2,379
    looks like it is stalling cuz it is hella lean
    have you looked into why the O2 sensor for bank 2 is not reading?
    the controller is in closed loop - it needs both of those sensors to function properly
    Advanced Tuner N2speed's Avatar
    Mar 2021
    Pompano Beach FL
    467
    Quote Originally Posted by kjlindgr View Post
    Hey all,
    Thanks again
    TUNE_CL_23.hpt
    idle-die.hpl
    you have bank 2 VE disable so you are not seeing what bank 2 is actually doing fueling wise. get that 02 sensor fixed and it may clear up a lot of your issues.
    P0052 - HO2S Heater Control Circuit High (Bank 2, Sensor 1) (Pending, Current)
    www.n2speed.com
    [email protected]
    Dodge And GM Tuning Support
    Diablosport CMR | HP Tuners
    The exhaust on this only had 2 O2 bungs so I'm using one of those for my wideband, which is why it's faulting one of the sensors. I had run this in OL by setting the enabled coolant temp to 300* and it effectively does the same thing.
    Mar 2021
    Pompano Beach FL
    467
    you can not do that with dodge, it needs both sensors, spend the 50.00 and add the 3rd bung for A/F, AEM even makes a clamp on version
    www.n2speed.com
    [email protected]
    Thanks N2speed, I will get one welded in.
    Regarding the idle PID settings for spark and throttle, do these look remotely close to what you would expect to see?
