Results 1 to 2 of 2
Thread: AFM valve enable (enable/disable)
    May 2019
    4
    Brand new tuner here .. so taking that uphill curve on learning.
    Working with a 2014 A6 corvette (base stingray)
    Ive figured out the tuning for a few things ..
    DOD -= disabled
    NPP exhaust tuning for opening things up when and where i want .. without need the M2W kit.
    I have a question after disabling the DOD .. Under the system/general/active_exhaust.
    There is an AFM valve enable - enable(default) or disable. Any benefit of going ahead and setting that to disabled? The plan is never to have 4cyl mode active again.. eventually doing a replacement build without those features.
    May 2003
    South FL
    1,592
    No need to mess with AFM valve if you globally disable DOD.
    And to adjust the NPP exhaust you have to license the CCM. Those functions are not in the ECU.
    [email protected]
    snackbartuning.com
    Owner/GM Calibrator
