Results 1 to 6 of 6
Thread: Dumb quick question about prolink, mpvi2+ and analog inputs/common ground
    Dec 2021
    5
    Question Dumb quick question about prolink, mpvi2+ and analog inputs/common ground
    Hi all. Setup is an mpvi2+, the prolink cable and using two different analog inputs on the prolink cable. I'll have two autometer sensors, and electric oil pressure gauge and a wideband o2. Each gauge has datalogging output, analog signal and ground. There's only one ground on the MPVI cable, so I'm assuming I'll be using a common ground between the two gauge datalogging outputs but just wanted to check. Told you it was a dumb question.
    Chris
    Dec 2021
    5
    Bueller?
    Bueller?
    Dec 2021
    5
    Appreciate it, however I'm talking about the MPVI2+ cable that has 2 inputs and a single ground. I mean it looks obvious to me, I just wanted some clarification.
    Senior Tuner LilSick's Avatar
    Jan 2022
    fountain valley
    1,998
    the red and the blue inputs on a mpvi2 share a common ground
    it is black
    Dec 2021
    5
    it is black
    That's what I was looking for. It's seems too obvious but I had to check. Thanks.
