Results 1 to 8 of 8
Thread: firebird help!!!
    Feb 2025
    4
    firebird help!!!
    i have a 97 firebird i started working on a year ago i just purchased hp tuners and got it running but it is sucking a lot of air at idle through the iac
    and idles high the rpms will randomly hang at 2500 i am new to tuning so im not sure what tables i need to change
    it has a 5.3 ls
    longtube headers
    a knockoff holley efi 92mm intake
    and a 92mm tb with stock iac and tps
    the part number for the injectors is 17091728
    i have my tune and log from a short drive here
    tune bird running .1.1.hpt
    log bird log 3.hpl
    many thanks.
    Jan 2015
    Arizona
    1,291
    that log is pretty much useless.
    need to add IAC trims, fuel trims, ill just see if i have one you can use check next post
    Feb 2025
    4
    thanks ill get a new log in a bit
    Feb 2025
    4
    log 4.hpl here is that log went on a short drive
    Nov 2006
    North Carolina
    4,861
    Quote Originally Posted by Jthom0763 View Post
    it has a 5.3 ls
    longtube headers
    log bird log 3.hpl
    many thanks.
    You have a injector circuit code. Usually means bad injectors or one unplugged.
    Those intakes and throttle bodes are very bad about vacuum leaks and poor fitting shafts/blades
    Feb 2025
    4
    i knew about the injector code but i had the injectors checked and a noid light on the wiring and it all checks out soo im not sure. im saving up for a new set of injectors and a new throttle body but i dont have the funds at the moment. i was just wanting a more experienced tuner to look over and see if anything big stands out that way i dont melt a piston!
    ps: thanks for the info
    Advanced Tuner abc's Avatar
    Jan 2024
    958
    Pull the fuel rail out with injectors still attached. Place paper towel under each injector and cycle the key, that will at least show you if all the injectors are injecting. Have a helper cycle the key and you can watch them do their thing to see if one is obviously out to lunch.
