I have had this car, 03 Z06, and others on Dynojet rollers, and have often wondered how accurate the wideband AFR readings are since the probe goes up either pipe, after the cat. I have heard some say that the only way to be accurate is to use a wideband, like a LM-1, mounted before the cats. Is that true??? What I want to know is how close, or how consistent do the dyno widebands read as compared to the LM-1 hooked up to the hp tuners EIO interface. How critical is the AFR on a normally aspirated car??? Also, how accurate is the hp tuner scanner reading of AFR Commanded, as compared to either the dyno wideband or the LM-1??? Any thoughts???
