hi guys I hosted my file HPI file if you don't mind.
just choes holden> search
http://www.horist.com/hptuner/search.asp?action=exe
Holden V8 A4, Comp Cam, Headrs, ASP pullys, K&N filter, HPTuner.&&
the file name Ali
Hey Ali,
I had a look at your bin file. I noticed you have LTFT turned off. I would suggest that would not be a stock setting. Apart from your higher PE setting (presumably to satisfy the requirements of that bolt-on engine mod) it looks ok. Also refer to my comment in your other thread.
Brian
Ali,
I might have asked this before but has anyone tuned the car before you? Are you working with an untouched computer? Also, does your car have 02 sensors? They look like little round tube devices with a wire(s) coming out of them that are installed in the exhaust. They should be close to the header if not in the header itself.
-Michael Rudolph-
2003 Redfire Cobra
Eaton Powered to a:
11.301 @ 129 1.68 60' MT DRs
11.85 @ 124 1.90 60' street tires
Brian and Screamn03 thanks guys for the time you spent to look at my file.
Ok, no one tuned my car before,(working with an untouched computer). Also, the Car does not have the O2 sensors, either the cathlec convertor. I did check my headrs and the whole system, they don't have any place for 02 sensors. What do you recommend me to do.
Hey Ali,
Can you get a log file(using the scanner) or histograms of timing LTFT's etc of the car running and driving?
You need to give us some more info to be able to help you.
On that note, can you tell us exactly what you want help with?
Is it to get the car to start..... idle...... running lean or rich...
Cheers
Brian
He's not going to have any LTFT data because it's an open loop vehicle, hence the problem.
-Michael Rudolph-
2003 Redfire Cobra
Eaton Powered to a:
Can I e-mail my first run to any of you guys and then you van learn. It would be a good cource . Because I asked the dealarship and they don't know anything excpt the 2000 model only came without O2 senser, but from 2001-2005 they do have. I'm trying to get as much info as I can to start doing some job. But if you guys having some small diffecult, for me it will big bigger. Let me know if Anyone want me to e-mail to.
And another problem came sometime the car will die on me. And when I jumb it it will start right away. And after cuople days or weeks will die again. Any Idea why.
Thanks guys HPTuner and you are the best.
Send it my way, [email protected].
-Mike
-Michael Rudolph-
2003 Redfire Cobra
Eaton Powered to a:
Ali,
I just took a look at you log file but I can't really make any suggestions at this time because there's no O2 sensor data. I'm starting to think that you are not going to be able to tune you car unless you get a wideband 02 sensor setup such as the LM1 http://www.innovatemotorsports.com/. What kind of gas do you run out there? Is it leaded or unleaded? What about looking into converting the car over to 01-05 Holden specs so you can enable closed loop? I would start with the wideband first but that's just another option you have. I really want to help you out but being half-way around the world doesn't help matters much.
I see knock retart in some areas but I can't tell why, is it because the car is running to lean or is it just false knock ???, it's kinda a shot in the dark, you know what I mean?
-Mike
-Michael Rudolph-
2003 Redfire Cobra
Eaton Powered to a:
Toss me a copy of the .bin and the .hpl file and I will have a look as well. Oh and in case I missed it, what exactly are you looking to tune? Are you having drivability problems, or knock retard problems? Also is the car an M6 or A4?
Matt
What's your email, I'll send them to you.
-Mike
-Michael Rudolph-
2003 Redfire Cobra
Eaton Powered to a:
Here's the .bin :
http://www.transamws6.net/HPTuners/bin/9163628314.zip
-Michael Rudolph-
2003 Redfire Cobra
Eaton Powered to a:
Hi matt what is your e-mail address ?
Thanks guys for helping me out I'm very happy to see how many friends I have without seing them.
Matt,
What I'm trying to get is..the engine shake, and any tune to give more power.
Mike I know what you mean....I don't know I think I have to look at the 01 cars and see what I can do...Thanks but it was a hard homework is't
Thanks agin
Can you send me the hpl file too?
[email protected]
Brian
Originally Posted by UAE_77
Yeah...I'm an idiot, [email protected]
Sorry about that. It's been real busy today at work, so I have been rushing through all the posts. Send it on over, and I'll give it a look. What RPM's is the engine shaking at? Is it just at idle or all the time? What are the specs on the cam? I assume it is aftermarket?
Matt
Ali,
I forwarded your message and attachment to both of them already.
-Michael Rudolph-
2003 Redfire Cobra
Eaton Powered to a:
