Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
Thread: What Wideband to use?
  1. #21
    Tuning Addict WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    8,093
    NGK or LM1
    Sulski Performance Tuning
  2. #22
    Quote Originally Posted by WS6FirebirdTA00
    looks like I was too late on this post, DO NOT BUY LC1. Those WB controllers are crap and you will be sending them back for repair to innovate. I went through 3 of these, friends went through several, they overhead, can't keep their programming, drift, don't have a nice output, is not portable, and so on.
    LM1 is ok but still has some oddball issues with it's memory. I like the NGK.
    Innovative does seem to have their share of QA issues. The first LM-1 I received was DOA (outputs were shot -- very common problem with these units). The replacement unit has worked flawlessly in the shop since (about two years). I don't log with it (it's wired up to the dyno software), so wouldn't know about memory issues. The exhaust clamp is crap though.
    If I had it to do over again, I probably would go with another unit. But once you get one that works, they work fine. And the replacement sensor is standard-issue, $50 at any auto parts store.
  3. #23
    Jan 2005
    Concord, NC
    8,093
    I really have had no issues with the LM1 other than it keeping the memory.
  4. #24
    4
    Hello:
    I come from Taiwan
    I'm looking for fjo wideband Handbook (PDF document) and software (PC and PDA)
    Do you have it? you can send e-mail to me?([email protected])
    Thank you ~
  5. #25
    4
    Quote Originally Posted by Russ K View Post
    I use the FJO wideband, and hooked up the analog output to pins 1 & 5 of the MPVI Pro interface. The scanner has the FJO pid already set up. Never had a problem with it, and have tuned many vehicles with it. Just let FJO know that you don't need their gauge or software since you are using the Hp Tuner's software/scanner.
    http://www.fjoracing.com/index.php
    Russ Kemp
    Hello:
    I come from Taiwan
    Thank you ~
  6. #26
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
  7. #27
    4
    Hello:
    That's not what I was looking for, I need software to record AFR
    Still thank you
  8. #28
    Feb 2017
    31
    I use an AEM X-Series 30-0300... it's my first WBO2 as well as my first foray into tuning. I was very happy with how easy the WB was to hook up, as I had read long articles for some of the others. The 30-0300 was easy as cake.. Power +, power -, data +, data -, and then plug it all in. Done.
  9. #29
    4
    Maybe I can try fjo connect AEM software
