Page 2 of 2 FirstFirst 12
Results 21 to 38 of 38
Thread: OK so whats the deal with WB's after cats?
  1. #21
    Nov 2007
    1
    What I don't understand is why you would even consider running your wideband after a cat!!! Everyone here has admitted that a cat does change readings, infact they HAVE to. Converters are in place to burn off excess hydrocarbons and convert carbon monoxide, The byproducts are water vapor and carbon dioxide. That's my .02 Hey alvin, you the guy from pcmforless?
    05 colorado 8lbs boost
    89 427w 'stang
  2. #22
    Oct 2004
    Orlando FL
    766
    I moved mine to the post-cat location due to a leak in the driver side collector. I didn't have a spot to weld in a new bung on the passenger side pre-cat. It'll move it back to the driver side pre-cat when I get new headers. I'm content with the minimal deviation in my data, though.
    1998 NBM Camaro Z28
    LS3 motor
    Mod list
  3. #23
    Tuner zzzybil's Avatar
    Feb 2007
    northshore neworleans
    101
    thanks for the chart
    looks like the car is already tuned tho ... nice to see a chart
    and wondering if a less tuned ( rich or lean ) would show a more exaggerated diff ??
    yes i wondered if thats the "alvin: too ..?
    sorta boggles my mind arguing if cat makes diff.....everything i've READ says it will and ??????....... a bung precat was not hard compared to the rest envolved in this process
    not to say "going to a shop " for something simple does not have its own inherrent issues........... ...........
    2.4 ecotech ( 2006 pontiac solstice )
    42lb injectors
    trim 50 garrett t3t4 (custom -barebones pumpking )
    boost @ aprox 7 <10
    38mm tial wastegate and bov
    3" tubes front to back
    werks radiator
    bell intercooler
    GXP,magna flo exhaust-with integrated dumptube by B_FASTER & R&D
    aem wideband
    custom manifold -by sh**er the skunk
    (((HP ))) tuning - in progress
    jet hot 2000
    aerospace logic egt kit
  4. #24
    Dec 2004
    Baton Rouge, LA
    12
    Quote Originally Posted by Alvin
    The wideband is referencing the atomosphere. There is no (very very little/none to speak of) oxygen in the exhaust at wide open for that reason there is no significant "burning" in the cat.
    If there is no/very little O2 in the exhaust(after-cat) at WOT(or any time, really...that's the cat's job is to use the O2 to break down the other toxins) then the O2 sensor WILL read rich compared to pre-cat, wouldn't it? Since O2 sensor measure O2? But the cat is only going to use whatever O2 it needs to break down the other toxins....so there is still plenty of O2 in the exhaust after-cat, but the reading is not going to be as accurate.
    But actually, there IS a lot of O2 in the exhaust.....hence tuning for (ex 12.5 afr....) 12.5 parts O2 to 1 part fuel. You will have a truer reading pre-cat versus after-cat.
  5. #25
    Sep 2007
    Florida
    59
    Quote Originally Posted by JimMueller
    Here's some comparison data from yesterday. LM1 is passenger post-cat, dynojet was driver pre-cat. Rounded to the closest logged sample.
    Code:
    Time	RPM	TPS	LM1	DynoJet	Diff	%
    18:00.2	2667	100	12.53	12.33	0.2	0.02
    18:00.5	2752	100	12.7	12.34	0.36	0.03
    18:00.7	2836	100	12.91	12.206	0.704	0.05
    18:00.9	2924	100	12.95	12.318	0.632	0.05
    18:01.0	3019	100	12.93	12.52	0.41	0.03
    18:01.2	3112	100	12.88	12.789	0.091	0.01
    18:01.5	3209	100	12.91	12.851	0.059	0.00
    18:01.7	3309	100	12.91	12.851	0.059	0.00
    18:01.8	3408	100	12.93	12.838	0.092	0.01
    18:02.0	3504	100	12.85	12.692	0.158	0.01
    18:02.3	3605	100	12.76	12.655	0.105	0.01
    18:02.4	3701	100	12.71	12.718	0.008	0.00
    18:02.6	3801	100	12.7	12.704	0.004	0.00
    18:02.8	3906	100	12.68	12.703	0.023	0.00
    18:03.0	4003	100	12.72	12.718	0.002	0.00
    18:03.2	4102	100	12.67	12.643	0.027	0.00
    18:03.4	4194	100	12.67	12.651	0.019	0.00
    18:03.6	4294	100	12.55	12.802	0.252	-0.02
    18:03.8	4407	100	12.6	12.764	0.164	-0.01
    18:04.0	4510	100	12.55	12.697	0.147	-0.01
    18:04.2	4618	100	12.63	12.629	0.001	0.00
    18:04.4	4717	100	12.74	12.68	0.06	0.00
    18:04.6	4828	100	12.82	12.794	0.026	0.00
    18:04.8	4932	100	12.85	12.959	0.109	-0.01
    18:05.0	5026	100	12.83	13.055	0.225	-0.02
    18:05.2	5132	100	12.88	13.122	0.242	-0.02
    18:05.4	5231	100	12.87	13.138	0.268	-0.02
    18:05.6	5329	100	12.99	13.09	0.1	-0.01
    18:05.8	5433	100	13.04	13.055	0.015	0.00
    18:06.0	5525	100	13.09	13.106	0.016	0.00
    18:06.2	5626	100	13.06	13.156	0.096	-0.01
    18:06.4	5723	100	12.99	13.185	0.195	-0.02
    18:06.6	5814	100	13.08	13.211	0.131	-0.01
    18:06.8	5908	100	13.11	13.206	0.096	-0.01
    18:07.0	6001	100	13.2	13.15	0.05	0.00
    18:07.2	6091	100	13.06	13.001	0.059	0.00
    18:07.4	6182	100	13.08	12.911	0.169	0.01
    18:07.6	6275	100	12.98	12.9	0.08	0.01
    18:07.8	6354	100	12.96	12.838	0.122	0.01
    18:08.0	6444	100	12.95	12.824	0.126	0.01
    18:08.2	6523	100	12.91	12.82	0.09	0.01
    18:08.4	6608	100	12.89	12.719	0.171	0.01
    18:08.6	6693	100	12.82	12.07	0.75	0.06
    I just found this thread, thanks alot for the graph. Nice to see the differences.
  6. #26
    Jan 2004
    Lebanon TN
    117
    Quote Originally Posted by alanderson1978
    I should also try a new sensor. Where's a good place to buy a Bosch WB sensor?
    Old post, just saw it, recently went hunting for a new sensor myself.
    Best price I found was on Amazon, free shipping too.
    Search there for Bosch 17014.
  7. #27
    Nov 2006
    2,801
    Wow, first time I visited this thread in a very long time.
    You guys have a very wrong idea of O2 left over in a rich mixture
    There is no left over O2 in a rich mixture, that is why it is a rich mixture. The only o2 that can possibly be left is that which is occurring as a result of combustion inefficiency.
    So, if there is no O2 left in the exhaust, there is no way any more "burning" by the cat can take place. Try keeping a match going underneath a glass.
    Tuner at PCMofnc.com
  8. #28
    Feb 2006
    central michigan
    349
    you need to multiply your % numbers by 100 to be correct.
  9. #29
    Feb 2008
    Sikeston, MO
    173
    Oxygen sensors don't just measure oxygen. They measure fuel and other gases as well.
    Post cat can make a difference. I hate doing post cat, and try not to. Plus the lag. At the tailpipe-some shops do it because it's easy. But the instructions for the different adapters often state short exhaust and no cats.
    Stock cars may not be in much danger, but some of the more radical setups...why chance it?
  10. #30
    Tuner in Training 346ci's Avatar
    Aug 2008
    37
    Quote Originally Posted by miker2 View Post
    I agree, threw me off at first
  11. #31
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,950
    Quote Originally Posted by GregRexAdams View Post
    Old thread I know...
    My comment is in reference to measuring at the tailpipe as mentioned above.
    I ROUTINELY run cars in OL with a WB in a front bung and I also use the tailpipe wideband on the dyno. I use it because it is there. The tailpipe pickup for the DJ almost without fail reads 0.5 leaner (AFR) than the one at the front EVEN IN THE CARS WITH NO CATS. I don't know where it comes from exactly, but I have seen it over 100 times easily. I suspect that is why so many dyno graphs are showing a 13.0 target being 'best'. I find that 12.6ish on my front wideband GENERALLY makes the most for N/A (though of course each one is a little different), and leaves the DJ AFR printout at 13.0-13.1.
    Just relating experience...
    Steve Williams
    TunedbyFrost.com
  12. #32
    Tuner in Training jdeatsch's Avatar
    Oct 2008
    Penfield, Neu Yawk
    35
    and the 'old threads' still contain GREAT info for us beginners who are just starting to approach the wb install and all that goes along with that.
    Thank you for this information. What a find for me.
    Jim
    Talk About NEWBIES !!!
  13. #33
    Feb 2008
    Sikeston, MO
    173
    Quote Originally Posted by Frost View Post
    I'm gonna go on a limb here and state that it's because of how close the sensor is to outside air. Some is in the tailpipe, whether you like it or not lol. Thus the leaner readings.
  14. #34
    Jul 2009
    509
    I'm new and still trying to understand wideband location. I can understand the lag from the wideband being in the tailpipe but is that an issue if you put the wideband in the rear O2 bung which is about 5 inches from the cats? Would it be worth the difference to have a bung put in front of the cats and if so, where is the ideal location.
    My car is a 2009 G8 GXP with the LS3 motor. I have ARH long tube headers and their catted X-pipe with the stock mufflers. I'll post a picture of the exhaust if someone needs it. Thanks.
  15. #35
    Jan 2006
    Richmond VA
    1,950
    If you are tuning (not just a monitoring WB) just pop out a front O2 and use his bung for your wideband.
    Steve Williams
    TunedbyFrost.com
  16. #36
    Tuner Nithros's Avatar
    Nov 2005
    Hermitage, TN
    125
    Resurrecting an older thread here since I have a related question. Is there any adjustment/calibration needed or available on a DynoJet for the O2 sniffer? The reason I ask is that on a recent trip to the dyno (a DynoJet with the O2 sniffer in the tailpipe) with the car just rolling - the DJ O2 was showing 15-16 some times and 12 at others. With the car just rolling (not at WOT), shouldn't it show somewhere around 14.6?
  17. #37
    Jan 2006
    Richmond VA
    1,950
    There doesn't seem to be enough exhaust volume at anywhere except for WOT for most tail pipe widebands. As I said before, I use a wideband in a front header/manifold and usually throw the dyno wideband in the tailpipe as well since it is there. The one in the tailpipe commonly reads full lean at idle but comes back somewhat in line with the front sensor as exhaust volume increases.
    Steve Williams
    TunedbyFrost.com
  18. #38
    Nov 2005
    Hermitage, TN
    125
    That makes sense - thanks Frost!
