Could someone help me wrap my brain around how to log manifold vacuum in a histogram. I would like to log the Injector Offset vs Battery Voltage vs KPA VAC tables, however the histogram will not load due to unsupported or missing parameters.
My vehicle (04 Ion Redline) has the LSJ engine.
The factory tunes default to using a Vacuum-based injector offset table.
This table ranges from -120 kpa to 80 kpa, which happens to correlate with the Injector flow rate table.
I have tried adding all sorts of parameters to the pid table but cannot get the histogram to display the way I want it.
Out of curiousity I switched to the Map-based injector offset table and bam! the histogram loaded and displayed immediately.
But the Map based table is ranging from 20 kpa to 200kpa and so I can't figure out how it relates to the other tables in the tune since the range is skewed.
I would prefer to log using the vacuum-based offset table so that it correlates with the ifr table ranges.
-120kpa to 80kpa.
thanks!
