Well my buddie(im sure he will chime in) is having a issue with getting this car to run correctly.
Its 2 bar now i used the map sensor off my cobalt ss supercharged car. It works perfect on there. the ve was copied over to the 2 bar. timing is set to 22 at idle. The car only runs 10degrees. And the map is PEGGED at 105 consistely. I suked on the map and got it to fall to 101 so i know it obviously works.
Long story short i put the stock NON 2 bar tune back in the car fires right up and idles like it used to before the blower on in. WHY? Leaving the 2 bar map in it now reads 45-50ish like it should be. When the 2 bar tune is in again the map is pegged and you have to have your foot in it to make it run.
Anyone got any inside info what i missed on doing.
why does it run perfectly fine start right up in a regular tune but when in 2 bar you cant keep it running the the map gets pegged at 105 at idle.
Kyle
