Results 1 to 8 of 8
Thread: ECU swap issues
    ECU swap issues
    Well, I change my old Ecu, with a new ecu. (Old one locked) with anther model. I have GMC truck Silverado & I make replacement with Holden Commodore 2002 I take it from junk, I make all changed and gone fine just 4 things. A/C not works at all, fuel gauge not work, battery light not close well battery gauge good read, speedometer move but run quickly.
    Saoud bin ajail
    Dubai p.o.box :24687
    United Arab Emirates
    Moblie:+971507744161
    WhatsApp:+971509345593
    [email protected]
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    Its because a truck requires a completely different operating system, insert the proper operating system and you'll be better able to tell if you have any other issues.
    Nov 2002
    Central Florida
    2,503
    In 2002 the trucks and F-body used the same hardware, do not
    know about the Commodore Holden though. You need to cross
    reference these platforms and see. If the hardware is different
    then the platform interface may be as well, wrong connector
    assignments are possible and so on. If the Holden PCM is the
    same type then writing a truck tune and VIN entire may bring
    it around. Do not know if you have to change the VIN first, it
    might be a good idea, some fussiness about VIN/OS match and
    having a Holden VIN may prevent you from writing the truck
    OS. I'd check into this, order of operations etc.
    Quote Originally Posted by Bill@HPTuners
    I use 6.0L operating system for that truck, i forget to tell that i swap the eninge to 6.0L ( I use all 6.0L file in that truck) & befor 5.3L
    Saoud bin ajail
    [email protected]
    Quote Originally Posted by jimmyblue
    The first thing what I do that step (changed the VIN), then I open VATS after I changed all hardware (file from 5.7L ls1 to 6.0L) is not matter, but what I think her is the wires in pcm is different must changed place I now that before the A/C signals get from wire #17 but want to check in these pcm also.
    Saoud bin ajail
    [email protected]
    If I can get the signal for the 2 pcm I can do it (I mean the wire diagram with run a/c by the services number) fuel & ather thing i think must check Ohms.
    Saoud bin ajail
    [email protected]
    Aug 2004
    Perth Western AUSTRALIA
    303
    Is the tune that you are using the one in this post ?
    If so it is the Holden operating system .
    Quote Originally Posted by Arron
    No , this Holden operating system what I make I use only Holden ECU with 6.0L operating system just for the motor mate .( ever thing is fine just what I mention : A/C not work ,fuel gauge not work , speedometers not correct ,battery light on but is good )
    Saoud bin ajail
    [email protected]
