Originally Posted by
SJSchafer
In that case, with meth I'm thinking you'll run a bit rich at WOT. Hopefully not so much that you'll get cylinder wash. I almost don't want to say this, because I am going by what I have heard, rather than what I know, BUT I have heard of people running 12.xx AFRs with meth, so if you set your PE AFRs to low 12s, you should still be cool if it goes richer. The only scary thing is that low 12s don't give you room if you run lean and without a WB, you won't know for sure. Stage 2 was pretty rich for me at WOT. I was commanding 10.8 and getting more like 10.4 or so.
The other reason I think you may run a bit rich is because meth is a form of fuel that you are adding to your system. Again, this is me just knowing engines, not necessarily meth. You may want to ask Area47. He has meth, and where he is more a timing than air/fuel guy, he has learned a bit about air/fuel lately and may be able to give you better guidence in this area.
