Page 1 of 2 12 LastLast
Results 1 to 20 of 33
Thread: Allison tuning
    Feb 2007
    SC
    61
    Allison tuning
    When will tuning be available for the allison transmissions?
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,279
    01-05 Allison tuning is available now, the 06+ use a different TCM that we are working on now.
    Advanced Tuner CRASHNBURN's Avatar
    Jun 2007
    Mn
    240
    Is it in beta now?
    2006 LBZ Duramax 4x4 CC SB 2500HD SRW 4x4 LT1 (with extras), Blocked & Fingered, Fumoto drain valve, Keystone Ram Air Good Hood, Banks Ram Air, Access cover & Rhino over the rails, Victory Red.
    33'-0" Dutchman fifthwheel,Tekonsha Voyager Brake Controller
    Banks Sixgun with HPTUNERS.
    Jun 2006
    eastexas
    104
    Bill,
    Can I get a beta copy as soon as yall get a release on the ally tuning?
    Any news from this...my dad has a droning noise in his RCLB 07 D-max and its the torque converter locking up too soon...I'd really like to help him up the speed on the lockup so that he can enjoy the truck.
    Jun 2007
    Mn
    240
    Quote Originally Posted by gofish7
    Is this in beta for the LBZ'S?
    Well...the engine for the D-max for that '07 is the LBZ.
    i've made some progress on this, shouldn't be too much longer i hope. early in the new year is a good bet.
    I count sheep in hex...
    Jun 2007
    Mn
    240
    Quote Originally Posted by Chris@HPTuners
    I know it is hard to predict. Are you says beta will start around then or it "might" be released to the public buy then? Have you had any progress in the taps reset? Thanks.
    Jun 2007
    Mn
    240
    Quote Originally Posted by CRASHNBURN
    I know it is hard to predict. Are you says beta will start around then or it "might" be released to the public by then? Have you had any progress in the taps reset? Thanks.
    Bump
    please email me a VCM Suite info and you can be a beta tester when it's ready. mid Jan is the likely date.
    Jul 2004
    25
    Any updates, I would love to modify the defuel settings in the TCM
    Jun 2007
    Mn
    240
    Last I heard the end of this month they are going to start beta. I would rather have them take there time & get it right at the alpha stage. It would be that much of a better product then.
    Jun 2006
    eastexas
    104
    I just put a set of 19.5s on my dually with 245/70/19.5 tires that are 33" tall I tryed to recalabrate the speedo and shift points and not avalable. Can't wait for beta. Though I do agree with you Crash. Sometime things dont go well when in a hurry
    Anything yet?
    Born on 11/20/06 07' GMC Sierra DMax EC 4x4 HPT
    SOLD:2003 Silverado ECSB 4x4, LQ9, Patriot LS6, TR230/224, 31lb inj, TB Stall, HPT & LC-1.
    Jun 2006
    eastexas
    104
    Bump... Bump.
    Jun 2006
    eastexas
    104
    Dont no, Did some tunning on an 05lly with trans tunning and still same thing. Must be missing a table somewere. More you push the worse it gets. Agian im clueless
    Dec 2005
    NV
    190
    I have a 06 truck to tune that has a 8.1 with an allison. but all the trans. tabbles seam to be there.???????
    2000 EC, SB Z71 03 LQ4, 05 front clip with e-fans, STS turbo, GT67, Blow off valve, 170Kpa, Alkycontrol, 44lbs injectors @ 100% dutycycle, Comp 918's, HPtuner, 02 ECM, Dyno Jet Wideband, Eaton LSD, Speed Engineering 4l80e conversion, 2800 ART CARR stall removed now running stocker . 11.87 @ 114
    New times 11.41 @ 119.. look out 10's here I come.....
    HP Tuners Support
    (foff667)
    28,279
    Quote Originally Posted by Wilde Racing
    The later model pcm's are weird in that they could support the 4 speed trannies so in many calibrations you'll see tranny parameters for the 4 speed but unless it read out the separate TCM cal modifying the 4 speed parameters will have no affect on your allison tranny.
    Feb 2004
    Macon Ga
    16
    Quote Originally Posted by blued turboed1
    same boat here...... just put 22.5's and 40" tires on 07 Kodiak, and cant change any tranny settings or speedo........
    Any new updates on when this will be available?
    *edit* I am already on the 2.2.1.0 beta, and willing to experiment, so anything available would be great....... Thanx guys
