Ok first off I have the VE table all within 2 to 3% error. Im getting started tunning wot and but the car wont go into PE mode. Commanded AFR starts off fine (~12.8/1.155 until 5200 and 12.9/1.13 on up in PE table) until I go over 4800 rmp them it goes back to 14.63 and commanding 34 degrees of timing. Im in OLSD maf is disconnected. Can someone point me in the right direction as I think im overlooking something. Here is a copy of the file and log. Histo: 6 is AFR and Histo 7 is the VE ratio error. If you look at the PID once I go over 4800 rpm the commanded shows 14.63 again at wot. The WOT run is about a min. in
