Results 1 to 3 of 3
Thread: Help with a new tune C5 427
    I just finished putting a 427 LS7 into a 2000 C5. I did a MAF tune on the car and it holds 14.7 at idle and at cruse. I decided to do a Speed Density tune on the car to dial in the MAF tune a little better.
    When I go into Open Loop the AFR jumps between 17-18 non PE, this also happens when in gear. When I have the MAF on it will hold the correct AFR 14.7
    I'm at a loss for where to look to correct this, I know its something simple and I ruled out any air leaks.
    Advanced Tuner arthansen's Avatar
    Apr 2004
    Tampa, FL
    425
    I think that means your VE table is way of. Try multiplying every cell by 1.3 (more fuel) and see if the ratio comes down. If it does, get it bellow your goal (by continuing to multiply by some number greater then 1) and then follow the SD tuning guide to dial it in.
    Let us know if that is it.
    2013 Jeep Wrangler JK
    3.6 V6
    More MODs than Stock
    2018 Ram rebel
    5.7 Hemi V8
    Stock
    It was a operator error everything is fixed know.
    2002 Quick Silver Z06 - Breathless Performance Shifter, DynaTech Headers SwainTech Coated, A&A Vortech Kit
