Results 1 to 10 of 10
Thread: A/C issues
    Nov 2005
    St. Louis, Missouri
    17
    A/C issues
    Hey guys,
    I went through the posts looking for a similar condition and found one with no help for the problem. Hopefully somebody has run into this before and could shed some light on it for me. I have a '00 Corvette that I did heads and cam on and everything is fine except when I turn the a/c on it turns right off. The system worked fine before the tune, I have to be missing something I just don't know what. There are several things that are very weird about it also....no matter where I set the target idle with the a/c on it will only go to 750 rpm. If I raise the rpm over 1000-1100 rpm the clutch will engage and the air works fine. The system is fully charged and the pressures are 32-35 and 180 +. When the a/c is cycling it is blowing 40 degree air. If I let the car come back to idle the the clutch will dissengage, the light will go out on the a/c head, but the car still has a load and draws the engine rpm down. If I turn off the a/c switch it pops right back up to the target 825 idle spec. I have taken the torque management out, put it back in, changed the timing at idle, air flow numbers, a/c bump....I am just out of ideas. Any help would be great.
    Thanks in advance,
    Joe
    Performance By Joe
    314-781-3135
    Tuning Addict WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    8,093
    did you resolve this problem yet or no?
    Sulski Performance Tuning
    Please help, I have this same problem on a 2000 pick up. The cam is messing with the IAC's causing the AC clutch to disengage at low RPM. What should I adjust to fix this?
    Nov 2002
    Central Florida
    2,503
    According to EC_Tune there is some sort of delta-RPM threshold
    for idle, where if it's bouncing too much it will cut off the A/C
    clutch. With a cam the motor is weak down low and the built in
    torque vs airflow model is no longer good. So the airflow bump
    that is meant to compensate the compressor drag, comes up
    short and the engine RPM sags, putting you into cutout cycling.
    If you supplement the A/C-engaged airflow (torque vs IAT vs
    A/C pressure) too much you will get into a A/C-on cruise control
    effect situation. So this (because it does not comprehend RPM,
    so no idle-specific help there) is not too useful and you don't
    want to mismodel the drag torque anyway; what we need is to
    fix the torque-airflow model but that is buried.
    One thing I can suggest to try, is the transient A/C torque
    values; maybe if you comp the initial bump that would be enough
    to get past the delta-RPM check. Try ratcheting it up and see
    if somewhere you get satisfaction. If so, tell me what you did.
    Torque Management >Engine Torque - Inertia Torque and its
    ramp in/out.
    There is also an A/C offset min/max, in/out of gear, which may
    need to be widened out to let the IAC add as much air as the
    A/C drag really needs. I'm not sure if the PCM tries to learn
    A/C offset or not, you could jack up the min and see if that
    props it up enough. This is in Idle Airflow.
    May 2004
    AUSTRALIA
    839
    Have you enabled any stall protect strategies?
    Nov 2002
    Central Florida
    2,503
    I have the "stall saver" RPM table populated, this is all I know of.
    Any suggestions about that, is the compressor cycling coming
    from the stall saver or are you meaning that stall saver will
    help with it?
    Tuner 1slowsilverado's Avatar
    Oct 2005
    Daytona Beach
    104
    Besides the A/C clutch what else does the Stall Saver affect and how?
    May 2004
    AUSTRALIA
    839
    Stall saver implements full derivative control when it triggers. It can stuff around with return to idle if you get some dip into the nether regions, causing overfuelling.
    I leave the stall saver unset, all zeroed out. The only stall saver strategy I use is the one under torque management, and set the RPM enable to 400. That way, my idle tune has a chance to do what it must before being blown out of the water by stall protect.
    Nov 2002
    Central Florida
    2,503
    I believe you hit the nail on the head, I backed down the stall
    saver RPM to 300 and it is happy now at P/N idle and almost
    OK in gear with the A/C. If it ever touches the stall saver RPM
    it still goes nuts. But the lower the RPM, the less the odds.
    I think idle should be tuned with stall saver zeroed. I was using
    it as a crutch and never got rid of it again.
    Thanks, Grant.
    Nov 2002
    Central Florida
    2,503
    Stall saver is definitely the root of the clutch cycling.
    I have had it yo-yo only once today, the clutch stays
    engaged but the RPM is unstable. I think this is still a
    MAP-dimension VE table problem. But on restart it was
    well behaved and did not yo-yo again. I think it's got
    to bury itself rich one time to set it off.
