Results 1 to 19 of 19
Thread: histogram display
    Tuner StarCaller's Avatar
    Jan 2007
    Cedar Crest, New Mexico, USA
    112
    histogram display
    out of a sudden my histogram shows only one line for certain parameters.
    first I thought the scanner didn't log right - loaded an older log from which I know there were all the numbers: same thing....
    so, got something misadjusted here or what?????
    28,287
    Post a scan, no sense in making us guess in what the issue is.
    Jan 2007
    112
    here we go:
    I know for sure that the "pecuris" one did show the numbers through the whole range.
    28,287
    They both work fine for me, I could only assume you have a custom PID setup incorrectly.
    Easiest way to fix it would be to delete your VCM Scanner.cfg file in your hptuners folder but this will delete any custom PID's you've setup, both correctly & incorrectly.
    Jan 2007
    112
    nope.
    deleted it, re-entered my # - same thing....
    then I loaded the 'default imperial.cfg' - same thing....
    didn't scan/log for the last two month, this was the first scan this year, so I really didn't change anything.
    28,287
    Ok, I'm thouroughly confused, you said you deleted it & you had to reenter some number?
    Sounds like you're deleting your VCM Suite.cfg file and not the file I asked you to delete.
    Jan 2007
    112
    got you....
    but no matter which cfg file I load - same thing...
    so I guess the failure is not in the cfg files... but it can't be in the scans neither (you're able to see all data).
    28,287
    I didn't ask you to load anything, all I asked is that you delete your VCM Scanner.cfg file
    Jan 2007
    112
    oh shoot....
    ok, did the right one this time.
    same thing. :-(
    28,287
    Is this stump the shwam? lol give me a few minutes to ponder other possible problems/solutions.
    28,287
    Well lets try this, please post the file named VCM Scanner.cfg file as shown in that screenshot I posted as well as the scanner config file you are using currently.
    Jan 2007
    112
    neither of this config files work, not even the default one.
    28,287
    secondly, go into your Start-Control panel-regional and language options
    What do you have the Standards/Formats language set to?
    Nov 2005
    Houston, TX
    3,968
    I thought this is what happened when you didn't log dynamic cylinder air?
    Bill Winters
    Out of the LSx tuning game
    28,287
    Quote Originally Posted by 5_Liter_Eater
    There can be a few reasons for this, but seeing that he IS logging dynamic cyl air, that rules that out in this case.
    28,287
    28,287
    Just checked your configs & they check out fine, probably your regional settings screwing something up.
    -Bill
    Jan 2007
    112
    you know what it was?
    not the regional settings (they were english & usa), it was the decimal symbol.
    a coma was selected & I changed it back to a period.
    odd thing, I wanted to see if I can change back to coma, but the only choice I have now is the period.....
    well, finally all's good again!
    but to be honest, I didn't even think about the regional settings......
    BIG thanx!
    28,287
    yeah, we see this alot with overseas customers using their native regional settings which changes the decimal to a comma which was what I was going for.
