I have several LS7 ??? Hope some of you guys on here can help. I have installed a ZO6 LS7 in my 1932 pro street truck. An am looking for some help.
1-I had to make a air intake it is 4" in dia' and I installed the stock MAF in it. Will that work OK? so say I should use a LS1-6 Mass air.
2-Speartech reworked the stock ZO6 PCM am got ride of all the junk I did not need. But I am running a turbo 400 tranny. What do you guys think? Is the tranny going to kill my HP?
3-I am using a weldon 600A external fuel pump with a bypass regulator. I have had two opinions about fuel pressure. 1-set it at 58 to 60 PSI at idle and not hook up the vacuum diaphragm and leave it like that. 2-set it at 50 PSI at idle the use the vacuum to increase pressure to 58 to 60 at full throttle.
4-I live in Tennessee. Who would be a good shop to take it to to make sure the PCM is tuned right for my truck? Speartech put a power tune in it already,but I would like to be sure I am right on for my truck. I have built custom stainless headers & a custom 4" cold air induction. Other than that it is stock.
Any help would be appreciated.
