Results 1 to 7 of 7
Thread: 2000 LS1 to 2002 LS1 OS
    I've got a 2000 Camaro SS and I did a write entire to get a 2002 operating system but the 02 OS I downloaded has the 1 Bar SD mode applied and I was wondering if I could "un" apply it because I want to run my Maf. At the moment it's back to my original operating system because I was under the impression that I couldn't use the 1 Bar SD if I'm running a Maf. I can't test this to see if it would work right now due to my interface being repaired. It should be back this week sometime but I was wondering if anyone had any insight on this. Would I be able to un-apply this then do another write entire? Thanks for any responses and your time. Mike.
    Tuning Addict WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    8,093
    Get a stock file and load it. You can't un-apply it.
    Sulski Performance Tuning
    That's what I thought but I don't have any more credits to get another 02 operating system.
    Feb 2006
    Buckingham (Doylestown) PA
    216
    Can someone post the specific differences between a 2000 and a 2001/2002 operating system. Is there a chart somewhere showing the differences?
    2000 T/A - Thompson Motorsports 416ls3, F1A procharger, HP tuned. Just a couple psi of boost.
    2013 Mercedes C350, wish HPtuners worked.
    28,298
    There are hundreds of changes even between 01-02 calibrations, the one major change from 00 to 01 is the lack of a secondary VE table in the 01+ calibrations which makes them slightly more desirable over the pre 01 cals.
    Feb 2006
    216
    So Bill, is it worth it to flash in a 2002 tune into my car? I've got 4 credits still unused, so it's not a big deal if it costs me 2 credits. Also, I realize that now my VIN would be changed, would that be an issue?
    FYI, I'm excempt because I drive the car less than 5000 miles a year, and it's actually closer to 1000 miles.
    Jan 2005
    Concord, NC
    8,093
    I still run the 2000 OS in my car. Only reason I would change is to setup the IAT bias, but I pulled my IAT sensor out anyway.
