It sounds like the way to go for tuning is the VE route, at least for the V8s....has anybody here been doing it?
If so, what are the results, where did you start, etc.?
Now that I've seen that other people have been doing it, and some method of doing it, I'm going to start playing with mine, and I'll keep you all up to date on how it's going.......if anybody else starts doing it, fill us in....
And, hopefully, some of the V8 guys will come in here, and give us pointers, slaps in the head, etc., to help us along......
So far, I've been leery about playing with too much, as I have to drive my car every day, so the only thing that I've really done so far is:
Tinker with the timing a bit, just adding a couple of degrees at most across the board, then tweaking it from there;
Bump my MAF flow rates to adjust for my MAF screen being gone (I increased them 2.5% (multiply by 1.025) as a ballbark guess, and it has made a noticeable difference in the way the car behaves).
And I adjusted the VE in one spot to help with a stumble when I hit the gas from idle, and that helped it out.
So, again, if you've been doing, or start doing it (and doing it is the in thing, now man), let us know how it goes for you.....John
