Having issues with mine. Initially I had an 02 sensor wire broken which put the computer in a not ready mode. I tuned the WOT PE anyways, once I fixed the wire the computer acts normal now and uses the BE table at whatever kpa I specify. Which makes it run rich whenever it comes into activation.
So the question is, if you tune the PE table and get it just right, what is the reason for the BE? Is it incase you didn't have a boost referenced FPR?
