Results 1 to 3 of 3
Thread: Entered My Car In A Contest! Need Your Help!
    Tuner krunchss's Avatar
    Jan 2008
    Brandon, Manitoba, Canada
    114
    Last day of the contest, still down by about 100 votes, or 65 points. If I had 65 people vote a "5" for my car right now, I would tie. Trying to find every little bit of support I can get today!
    http://autos.winnipegfreepress.com/i...ts&sort=points
    My 2002 Monte Carlo SS is currently the second car in this list. Click my car, then you should see a rating bar above my car of 1-2-3-4-5 Click your appropriate circle next to the rating you wish to vote (5 I hope ) and that's it!
    Thanx,
    Krunch
    2002 Monte Carlo SS "Project Intimidator"
    [*DHP PowerTuner*] [L36] [180 TStat] [ZZP HVTB] [HV3] [Resonator & U-Bend Delete] [Carsound Hi Flow Cat] [Corsa Catback] [P&P OEM Manifolds] [Precision PT61] [ZZP Trans] [3000 Stall] [2.93 Gears] [F-Body Calipers] [Water-To-Air IC] [AFCO Ford SVT HE] [IAT Post-IC] [Bosch IC Pump] [9.5L System Fluid Capacity]
    Mar 2006
    Regina, Saskatchewan
    141
    rated you.
    good luck!
    Chris T.
    2014 F350 6.7 Powerstroke.
    2008 Ford F350 Super Duty 6.4L 72MM turbo
    2007 Escalade 6.2L
    2007 Yukon Denal 6.2L
    2010 Lexus RX350 3.5L
    2001 Tacoma 3.4
    2000 Camaro SS LS1 M6 - STS Turbo
    1998 Dodge Cummins 12v 5spd
    1998 Topkick Cat 3126E 7.2L
    1983 Toyota Pickup
    1982 Toyota Pickup
    2006 DRZ400
    2008 Turbo Nytro
    2010 Skidoo XP 800
    1978 Corvette
    Jan 2008
    114
    Thanx for the support, but when the deadline approached, I was about 30 "5" votes too short.
    Ah well...
    Krunch
