Ok I think I did this right if someone could check it out and tell me if I messed anything up I'd appreciate it.
My g/f has a 2001 3.8 camaro. Recently put in 24lb injectors. From the data I gathered she has 22lb stock @58psi and new ones are accel 24lb @58psi. Searching on the forums I found a formula to increase the injector flow rate and I came up with this:
https://home.comcast.net/~sd_fleishman/INJECTORS.zip
It's an excel file btw.
Thanks!
