Results 1 to 11 of 11
Thread: A4 shift, TCC, TM performance tweaks - Excel tbl
    Nov 2002
    Central Florida
    2,503
    EDIT: This 'sheet has been superseded by a more
    recent, cleaner and more-tweaked-up one, and
    others are now hosted too; see this thread:
    I have gotten to a pretty nice set of settings. I put
    them into a nice formatted Excel sheet so it should
    be "portable" between various FBody years etc.
    Do not know if it's entirely compatible to 'Vettes
    and other platforms, but worth a look. You can cut-
    n-paste the tables into corresponding VCM_Editor
    tables 1:1.
    http://home.cfl.rr.com/jimmyblue/JWS..._20040427A.zip
    Feb 2004
    Macon Ga
    16
    Re: A4 shift, TCC, TM performance tweaks - Excel t
    Brake Shift Pressure vs Torque vs Gear ....i was looking at this on mine last night.....anyone know exactly what it does, and is it related to TQ management? I at first set mine to 0 also, then thought it was a trans line preasure thing, so I changed it back..........any help anyone? Thanx
    Nov 2002
    Central Florida
    2,503
    I believe it just limits line pressure when your foot
    is on the brake; my stock program has this zeroed
    and I didn't change it. Might have some value in
    towing apps (engine braking) - or not.
    Apr 2004
    Melbourne, Australia
    64
    Thanks for sharing. I've noticed some of your trans based questions and comments go unanswered on the forum. As I purchased the VCM suite almost solely to fine tune my trans cal, I've appreciated your posts so far.
    Apr 2004
    East Tennessee
    339
    I just downloaded your xls file. I am a M6 guy but I have a friend with a 2001 A4 C5 Coupe. He was wondering what exactly do all these changes get you???
    Thanks,
    Quote Originally Posted by jimmyblue
    tables 1:1.
    2007 CTS-V LS2
    Nov 2002
    Central Florida
    2,503
    Mainly, downshifting that "pulls in" pedal-proportional
    (not no-kickdown-until-WOT), more like an old-school
    vacuum-modulated or TV controlled tranny. And no TCC
    lockup in 3rd, so it's more "sporty" w/ my mild TCI3000.
    I would take these as a starting point, try 'em, file-to-
    fit.
    Quote Originally Posted by SideStep
    Thanks,
    May 2004
    Near Austin, TX
    82
    jimmyblue,
    did you ever get any resolution to the Brake: Shift Pressure Vs. Torque vs. Gear???
    I can't help but wonder if it shouldn't be reversed on the left hand side of the table ordered like this... 2->1 instead of how it is marked 1->2 etc. etc.
    Unless of course, the table is about the shift pressure when it downshifts. IE: you are in 4th, at 45 and you WOT. You downshift into 2nd, I wonder if this table describes the shift pressure during that process??? But then again, it would be mislabled at the table level. Any ideas? Has anyone played with this this table? I ask because, when mine downshifts, there is very little felt shift pressure, but there sure is a lot when it upshifts!!!!
    Because it must be Brent!&&\'05 FORD F-250 Diesel, baby
    Las Vegas, Nv
    64
    Since this says no lockup in 3rd, your mpg would be greatly affected by the driving conditions right? would the converter lock on normally @ any point?
    fit.
    2000 Trans Am WS6 - Bright Red : 12.36 @ 110 - 1.832 60
    228/232 .571/.588 113 LSA | JetHot LTs | Yank ST3500/2.5 | SLP lid
    Nov 2002
    Central Florida
    2,503
    Updated Excel tables hosted & added thread link to
    original post.
    Las Vegas, Nv
    64
    just wanted to say ive used this table and it works awesome..will take some tweaking though.
    jimmy: I like how the car is so responsive and kicks down a lot sooner...but i may want the shifts a bit softer.
    In order to find my happy medium, would i just leave the line pressure table alone? Or maybe i should ask...What creates the affect of having better throttle response?
    Nov 2002
    Central Florida
    2,503
    A low shift adaptation time makes the trans use "as
    much as it needs" to get done on time. I think this is
    the main key to throttle responsiveness. Upping shift
    pressure makes it use that much, needed or not. I
    have been upping force motor pressure (shaving down the table current) trying to control my TCC slip on
    highway grades, etc. with my TCI converter. If the
    shifts are overly hard I would back off on the shift
    pressure by load first. If you feel like there is slip on
    high-throttle shifts then maybe put some back.
