TCC tables
What is being adjusted on the TCC Apply/ Release vs % TPS vs Gear tables? What is %TPS? What does the number being entered in the box refer to?
Re: TCC tables
Torque Converter (lockup) Clutch is what you're setting.
Apply = lockup, the value is the speed above which to
lock at (X-axis) TPS (throttle position sensor) %.
Release is the flip side, speed below which to release.
You want some deadband in speed or TPS%. It may
help you to look at the graphical views. I also made a
"visualization" spreadsheet or two which you should
find on the .bin repository sites now, or shortly (not to
be taken as guidance, as much as helping you see the
relation between gear change and lockup clutch action,
which can get tangled up once you start moving the
part throttle profiles around).
