I would like to use the tow/Haul functionality of the 2000 5.3L engine that I have swapped into my landcruiser. The tow/haul switch is connected to the BCM (Body Control Module) which sends a message to the PCM when the switch is pushed. Unfortunately I do not have a BCM in my swapped setup. Could someone with 2000 truck or suburban that has 5.3L or 6.0L engine sniff the messages that are sent when the switch is pushed and post them? I am hoping that with the version 2 ELM chip I will be able to send the correct 3 byte header and message onto the buss to enable and disable the tow haul mode.
Thanks for any help,
Vortec62
