Results 1 to 4 of 4
Thread: Security access denied (98 to 99PCM)
    Tuner 01 MidMet WS6's Avatar
    Jun 2007
    St Paul, MN
    169
    Hello,
    I am trying to tune a 98 Camaro and cannot get passed the Security access denied screen during a read entire. I have been told that this vehicle has a 1999 pcm (installed at another shop). How do I get passed this? Is it an issue that the VIN does not jive with the PCM? Also in the write entire screen there is no OS # nor a TCM OS#. I have access to a Tech 2 and could do a dealer reflash if that would help but do I reflash to a 99 VIN or his current? Also, If I have another licensed 99 file could I perform a write entire and start from scratch? Thanks in advance!!!
    Carl T.
    01 WS6-M6, PRC Stage 2.5 5.3's, MS4, Kooks 1 3/4", custom built full true duals w/ X-pipe, SLP lid, tuned via HPTuners
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,290
    Sounds like the pcm has been tunerlocked.
    Jun 2005
    Southern FL
    2,044
    Carl, you can't just install a '99 pcm into a '98 F-body. The wiring is completely different. It would have to be repinned, and there is like 1 or 2 sensors that have to be modified/swapped. This is a painstaking process, too. Some have elected to install a '99+ wiring harness. You'll have a leftover plug, and there is a gentleman on LS1Tech that has done several of these swaps, and knows exactly what to do here (you'll have to do a search).
    Formerly known as RWTD
    Toys: '22 Tesla Model S Plaid / '20 Chevy Duramax / ?20 Sea-Doo RXT-X (2)
    Jun 2007
    St Paul, MN
    169
    Update:
    The PCM that was in the car was previously tuned using Tunercat and although it supposedly was not locked there format must not be readable by HPTuners. That being said I installed a PCM from a 2000 Tahoe, disabled VATs and used that instead. Everything went well other than the A.C. no longer works and the Fuel Gauge is inoperative. I heard that there is a segment swap available using express van tables? Anyone know anything about this? Thanks!
