Results 1 to 14 of 14
Thread: What enhancments does A-tap V2 cable have over V1
    Sep 2002
    Chicago, IL
    6,395
    Anyone know the actual capability differences from a programming standpoint?
    I know the packet protocol is a little different with a different header.. but what else?
    What can the V2 cable do that the V1 won't?
    I'll e-mail autotap and see what they say but I figured I'd post here as well.
    We got this guy Not Sure, ...
    Sep 2002
    Chicago, IL
    6,395
    Re: What enhancments does A-tap V2 cable have over
    Also, did a little more digging..
    JPatrick of autotap stated that the only difference between the LDVXXXP1 and the autotap V2 device is the model # they report
    which is also interesting.. as the VIA device is $149.95
    Autotap has 2 cables that you can chose from, both are V2 I assume:
    OBDII Generic Parameters KAT1WG $199.95
    OBDII Generic & GM's Enhanced Parameters KAT1WEPT $289.95
    Right now.. I'm just confusing myself.
    are the cables actually different? enhanced parameters would be a function of software I would think..
    The more I try to find out about cables and what they can do.. the more I get confused or filled with misinformation. I swear most of those people had the cables designed for them and they just do the software...
    Business Network Solutions - for all your PC, network, printer and computer security needs.
    Sep 2002
    Chicago, IL
    6,395
    Check out the links page with some of the new interface links I put up.. Lots of good stuff on there. Some are straight through, some use the ELM device, and then there is the B&B devices... that kinda sums it up..
    in the end, it's still confusing.
    I e-mailed autotap, I hope they respond here.
    Sep 2002
    Chicago, IL
    6,395
    I e-mailed orders@B&B by mistake and didn't really get the answer I was looking for..
    My one concern is about packet length... I guess I'll find out in a few days when I start to play though.
    Dec 2002
    Yardville NJ
    40
    In B&B's LDV doc http://www.vehicleinterface.com/asse...xxP1-1103m.pdf it says on page 3 Firmware4 Revision History
    Version 1.XX Not Applicable Old 15-byte fixed lenght
    hope that helps
    Sep 2002
    Chicago, IL
    6,395
    Ahh cool. I had that document on my desktop already.. Nice find.
    Hi All,
    Sorry I've been away so long.
    EFILive uses both the AT V1 cable and the AT V2 cable so I have programmed against both APIs. They are *very* different APIs.
    Just off of the top of my head...
    The V1 API is fixed length 15 byte packets.
    The V2 API uses a variable length message made up of a variable length header block and a variable length detail block.
    The format is like this:
    <start of frame=$01><Header length byte><header data bytes><detail length byte><detail data bytes><checksum>
    The V1 is fixed at 19200 baud, the V2 has a programmable baud rate up to 115200 baud. On some data logging operations this gives up to 30% faster throughput.
    The V2 has some "smarts" built in - it autodetects the OBDII protocol of the vehicle and reports it back to the PC based application.
    The V2 has a checksum byte the V1 does not.
    The V2 reports back error messages the V1 does not.
    Paul
    Sep 2002
    Chicago, IL
    6,395
    Thanks again Paul, you have provided a plethora of information on this forum.
    That answered alot of questions I had..
    Thank Paul!
    Can it be used to reprogram??? LMK
    THanks
    Guest
    Guest
    Quote Originally Posted by ls1tools
    Hi All,
    Paul
    What's the maximum packet size on the V2? same as the LDV?
    The API allows for up to 256 bytes, but it is physically limited to 32 bytes.
    I do not believe it can be used for reprogramming.
    But just because I don't think it can doesn't mean it cannot.
    I don't fully understand *ALL* the requirements for reprogramming so I can't say for sure.
    Paul
    Sep 2002
    Chicago, IL
    6,395
    Check out the very large Flash Protocol thread for a little snippet on my latest findings regarding flash programming requirements. I'm not going to hijack this thread. There is a lot of good reading there.
