Page 13 of 20 FirstFirst ... 391011121314151617 ... LastLast
Results 241 to 260 of 399
Thread: Truck Owners
  1. #241
    Also tuning my truck
    09 Silverado 4.8
    I have added 4.11 gears
    I have removed all TM (i think) and have moved the high spark table to the low and smoothed out. I am still reading up on other things. So its a big learning curve.
    The truck really does feel so much better now. I feel it is so much smoother.
    Anyway lets try to make this a tips and tricks of what works and what doesn't, I know I need all the help I can get!!!!!
    2009 GMC Sierra All Terrain Z71
  2. #242
    Am here also,
    Switched from 2005 GTO to Hummer H2 and am doing my own tuning.
  3. #243
    2008 Silverado extended cab and very short bed with L76 Vortec Max engine, 4L70E trans, 3.73 gears and 2wd Z71. I have the vararam intake and gained more than 20 rwhp MORE THAN the K&N 63 intake I had previously on it. I just have one question regarding my brothers 2005 reg cab short bed 4x4 electric fans LM7 5.3 truck. He's been asking me for the best cold air intake for it and I personally have no idea about the VR-6 from Vararam to whether or not it is great or not. I want to see what you guys with those trucks feel are the best intakes for it. Any input would be greatly appreciated.
  4. #244
    Sep 2010
    colorado springs
    20
    2004 chevy avalanche
    Hi I have a turbocharger z71 chevy avalanche, stock 5.3 with a z06 cam & springs.I home built the rear mount set up with a t62 turbonetics turbo.It has 60lbs injectors. It made 483rwhp 516rwlbs torque. It weights 6000lbs,ran 13.42 at 105 spinning all 4 tires past the 60 ft mark ,in colorado at over 5000 ft .running 8psi . I replaced the the 4l60e with a 4l80e. After blowing up 6 build 4l60e and one stock 4l80e. I dont under stand how some of you are going into the 11"s with 4l60e . I had the last three build to support 600hp . tci front pump,beast sunshell,5 gear pinion,kevlar clutches,hardened input & output. The works.I got a 13.23 at 106 this last summer.
  5. #245
    Tuner in Training Darrel's Avatar
    Nov 2010
    Dunedin Fl
    22
    88 Jeep Wrangler running a 2002 Silverado 5.3L
    I have a 88 Jeep wrangler that I put a 5.3L / 4L60E / NP231. I had paid for a guy to tune it and I think he did a great job. But there are some things I want to change. Such as soon as you start the motor and put it in gear it wants to hard. I have gone to 1 Ton brakes to keep it down. (Yes the TCC voltage is being applied when I hit the brakes to tell the torque converter to release It ) just does not feel like it is. But it does scream when I get with it. I just have so much to learn.
  6. #246
    Advanced Tuner silverbullet08's Avatar
    Dec 2009
    Houston, TX
    453
    89 chevy with 08 5.3 LY5 swap
    Headers, catless 3" dumped, 3.73 locker, intake, Hptuned, and 100shot ready to go.
    HP-Unlimited Tuning and Custom Fabrication
    Houston area performance parts dealer
    MD800 Mustang Dyno 713-560-3889 Taylor
    2016 Camaro A8 "shop car" FIRST 6th GEN CAMARO OVER 200mph IN THE MILE 203.5mph
  7. #247
    2004 Sierra RST 4.8 5spd here - K&N CAI, JBA Short Tubes, Cat-Back, 3.73 G80
    I've been fumbling around with HPT for about a month now, but starting to get the hang of it. I can definitely notice an increase in drivability. So far I have VE, MAF and PE tuned and will be starting on spark/timing over the next few days. I hope to get it on a dyno next week and run stock vs a couple of different pe setups and to verify AFR.
    This is my first performance upgrade purchase, and couldn't be happier...will definitely save on headaches/downtime for future upgrades.
  8. #248
    Jun 2009
    Staten Island, NY
    14
    Just picked up an 07 Escalade and once my parts arrive I'll start tuning.
    1998 Sebring Silver Camaro SS Vert A4
    H/C/I, Gears, Converter
    2009 Stryker Blue Pontiac G8 GT
    Kooks 1 7/8 LT's, Catted X, Vararam, HSRK, EFI Alchemy tuned....348 rwhp 362 rwtq
    2007 Black Raven Cadillac Escalade
    Vararam, 2" leveling kit, 305-45-22's
  9. #249
    Jan 2011
    1
    Just recieved my HPTuner software. Wow is all I can say. I bought it because I am getting a misfire warning. I have been told it was due to the CAM I had put in it. Hopefully this will help me find out.
    ___
    2006 GMC Sierra Crew Z71
    Crane GM LS Quick Lift CAM
    Magnacharger
    JAB Headers
    Magnaflow High flow Cats
    Magnaflow Cat-Back exhaust
  10. #250
    Oct 2009
    8
    I have a 2000'swb single cab.. Tuned by me via lm2 wb and hp tuners. Crate ls6 longblock with a baby cam. Acell 32 lb injectors, Longtubes. 2.5" true duals with x pipe, 2500 convertor, 4.10 gear. Everything else on the motor is off my stock 4.8, from the intake to the clutch fan.. It's been 12.97 @ 104 on drag radials and 13.20's on 20" rims and street tires
    68 camaro. N/A 385 sbc, full interior, 3280#, 10.30's @ 128+....all motor
    2000 RCSB Silvy crate ls6 longblock, baby cam, 2500 stall, 4l60e, 4.10's... 12.60's so far
  11. #251
    Mar 2010
    10
    2007 chevy silverado
    4.8 tuned with hptuner. About to have full exhaust headers, high flow cats, and corsa exhaust out the back. Possibly CAI, cam, and nitrous if money works out.
  12. #252
    Mar 2011
    Mid West
    97
    2008 Trailblazer SS AWD LS2
    Family, I need some help w/sizing a small turbo to go with the LS2
    E-85 tune
    Mild bolt ons
    Small turbo
    NOS
    E-fans
    Cat back Flow Master
    Thanks,
    Mr. 2008 SS
  13. #253
    Mar 2011
    San Luis Son Mexico
    43
    74 blazer VORTEC
    Ive got an offroad use only 4x4 1974 blazer .Can somebody send me a good tune for its 5.3 2004 vortec, standalone wiring harness, rear o2s canceled, open headers, 350 tranny, 272 transfer case, 33 inch tires, 340 gears. Actually Im at zero right now. Anybody have anything similar eliminate cats rear o2s the most gas I can get out of stock inj. from the pcm .I got my hp tuners a week ago perty new to this .All I need is a good tune so I can go test drive it this weekend
    Im really new and am trying really hard to understand the tuner any help will be greatly appreciated Email [email protected] San Luis Sonora mex.
  14. #254
    Mar 2011
    3
    Hello New to Hp tuners with trucks.
    Used to Gto's
    Anyway is there a program I can download and save somewhere to get me started with tuning my 05 silverado for MPG.
    I want to lean it out, play with spark tables, and so on. Any recommendations or links to download a file would be great.
    2005 4.8 5 speed rcsb silverado.
    headers, high flow cats, cat back, stock gears, 20 inch wheels, 2wd, cai, granatelli MAF sensor no screeens, NGKtr55IX plugs, msd wires.
  15. #255
    Jun 2007
    Saskatchewan
    13
    I've had the Pro software for a few years now. Did a wee bit of tuning on my 99 Sierra. But the 08 V Max I just bought is making me wanna get rid of the other hot rods. I'm too poor to buy horsepower parts now, so I've decided to learn how to tune. Plus I've set myself a goal of keeping the truck faster than the 440 '70 Charger my buddy is putting together!
  16. #256
    Tuner in Training cdb09g8gt's Avatar
    Sep 2009
    Johnstown, PA
    19
    I've had the Pro VCM Suite for about 2 years. I still consider myself a newbie, just don't have alot of time to dive into it very deep, but I'm slowly getting there. I have a 2010 GMC Sierra 1500 Crew Cab SLE 4WD with the 5.3 (LC9), 6L80E, and 3.42's, all stock as far as powertrain, just some suspension mods. Actually, I have just started tweaking on this truck, but I played with my G8 GT when I owned it last year. Future mods: catback, headers, Maggie....... well, maybe someday on that one!
    Info for the truck guys is sparse, at least compared to what I was used to with the G8 community. But lotsa great info from the regular tuners here.
    2010 GMC Sierra 1500 Crew Cab SLE Pure Silver-Hauls family and stuff-New Hot Rod
    2004 Chevrolet Silverado 1500 Crew Cab 5.3L-SOLD
    2009 Pontiac G8 GT 6.0L-Hauls ass-SOLD
    1995 Chevrolet Camaro Z28-Hauls serious ass-SOLD
    2002 Saturn SL2 1.9L-Hauls groceries, white like most other appliances
    You Tube Channel: http://www.youtube.com/user/roadracing3?feature=mhum
  17. #257
    Sep 2009
    Johnstown, PA
    19
    Quote Originally Posted by JUSTINRST View Post
    Used to Gto's
    With so much advice here at this forum, you can't go wrong. It just takes some time to pick through the info.
  18. #258
    Mar 2011
    Mid West
    97
    2008 SS trailblazer AWD getting HP next week...
    cat back
    K@N
    Turbo very soon
    Thanks,
    Mr. 2008 SS
  19. #259
    Mar 2011
    Mid West
    97
    Just got my HP Pro tonight
    Cat back
    k@N
    Turbo soon etc
    Thanks,
    Mr. 2008 SS
  20. #260
    Nov 2010
    Hermosillo, Sonora, Mexico
    37
    South of the border 69 C-10
    I also have a truck that I am tuning.
    It is a 1969 C-10 and I added a '06 4.8L and a '99 4L60E.
    I have not yet started it but I might do that tomorrow, as soon as I finish the fuel system.
    The engine will be left stock save for a free flowing exhaust and a performance/economy tune since it will be the truckshop driven on a daily basis.
    I am very tempted to drop the cam I goy out of my LQ9, which is the same part number as the one GMPP uses in the 327/327.
    But then again I want to keep this engine stock.
