Results 1 to 5 of 5
Thread: Tcc question
    Tuner 1FastLS's Avatar
    Mar 2005
    Warrenton, va
    62
    Tcc question
    Tcc apply/release speed vs tps table
    the numbers represent mph correct ? so why in 2nd apply always like 254 256 or in the 125 range wouldnt you want the numbers lower to lock the converter. couldnt find anything to explain this. anyone
    tried deleting question found answer
    Tuner 1 day
    Advanced Tuner gman4dx266's Avatar
    Jun 2006
    Cape Coral, FL
    860
    For others that find this question, ill post a short answer:
    On a stock converter & transmission, you do not want to lockup the converter in 2nd gear, especially when you go wide open. That is the big no-no. I, personally, have torn a converter clutch to smitherenes doing douchey stuff like that on the stock converter. So basically setting that table to a speed that is unreasonably high for the gear you're looking at will disable the lockup. Just to be safe though, set it to 256 to completely disable it with absolutely no chance of wheelspin necessitating a lockup because of the mph increase.
    Btw, nice avatar :-P
    Jul 2005
    18
    There should be less stress on the TCC in 2nd gear in 3rd gear due to the gear advantage 2nd gear has over 3rd.
    The stock tunes lock the TCC at WOT in 3rd gear.
    Why would 2nd be worse? The 4l80e's lock in 2nd gear.
    peace
    Hog
    May 2007
    489
    The torque in 2nd and the size of the factory clutch in the converter will have alot to do with lockup in 2nd as well.
    May 2006
    27
    Glad I read this b4 I screwed mine up ... thanks
