to complete it self, I am having a hard time passing emissions, 02 monitor is completed and all the others are completed under the DTCs in the scanner, is there a certain procedure for this to work? thanks for any help.
PB... [email protected]'@1.807 no nos.
Zzp 1.9 rockers,42.5 lucus injectors,poly motor mounts 3.2", custom K/N FWI, Autolite 104s, 180*t-stat, DHP PCM, Pacesetter headers, 3" down pipe, highflow cat, 3'' exhaust to bullet mufflers. Zex dry kit with 75 shot, thrasher throttlebody spacer, Stage 2 dynotech race tranny, 3.29s, 15/16s chain, hardened imput shaft, 3000 pro torque converter.
Is it possible you have that test turned off?
2005 Grand Prix GTP
My CarDomain Page
I went under engine diag...in the editor and clicked on DTCs and the list comes up I have the first one on. SES enabled and error mode set to 1. bank one sensor one heater control circuit, and the other readiness statuses are completed, the 02 sensor is completed but the not the heater. I do have a 02 sim on the second sensor, do you think that is causing my problem?
I've owned the car for about 4 years and never had a problem passing emissions.
Maybe a problem with the O2 sensor itself?
2005 Grand Prix GTP
My CarDomain Page
ya if it was that. I think it would throw a CEL. right? maybe not I dont know
