I am Working on a 1999 LS1 Corvette The Motor specs are as follows Stock Bottom end, AFR Heads 205cc Street heads, A Lingnefelter Cam Duration @ .050 207 / 220 Valve lift .573 / 580, and A Magna Charger with 4psi of Boost.
The problem I am having is at light throttle (regular driving) in 1st and 2nd there is a dip in power at 1800 rpm, at free rev there is a surge there too, Only at 1800 RPM.
I am including two Pictures. The first one is free rev at 2200 rpm where everything looks good to me, it is the same at any rpm besides 1800. The second is at 1800 RPM where you can see on bank 2 the short term FT has to make large changes to switch to O2 from rich to lean, Bank one looks normal. I also noticed when it does this is only when it all 100% all the way up to temp. The fuel LT trim also even bank 1 to bank 2 all the time except at the magic 1800 RPM where Bank 2 differs from bank 1 by about 10%.
This is a return less fuel system with the inlet on bank 1, If that makes a difference. I also looked into the proportional fueling tables and made sure they matched bank 1 to 2, Which they do.
Anyone seen anything like this Before or have any suggestion.
Ward
