Will HP Tuners do a 92eagle talon tsi?
1967 camaro LS2/M6
2001 Formula LS1/A4
Those require a chip burner if I remember correctly.
Either way, it doesn't support it.
DAMN! thanks anyway.
1967 camaro LS2/M6
2001 Formula LS1/A4
I don't know whats inside the ECM of the Talon, but if there's a Chip which is compatible with the 27c32, 27c256, 27c512, etc. you could reflash it.
There may be a XDF or ECU file on the Net which can be used with Programs like TunerPro. So you don't have to find every single value and table by yourself. If that is the case, you could read it with a Programmer, modify it und burn it back into the chip.
I reflashed the ECM of my buddy's Firebird several times and it works great.
Maybe this leads you in the right direction.
'97 Jeep Grand Cherokee ZJ, 5.2L (Canada Import), 2" Lift
(CAI, Modded Kegger, Ported TB, 3" Cat-Back, SCT Custom Tune)
'98 Jeep Grand Cherokee Limited ZG, 5.9 V8, Stock
'03 Skoda Fabia, 1.4L 16v
'98 Chevrolet Camaro V6, 3.8L, Targa, ZZP GT1 Cam, Dynomax Cat-Back [sold]
what year firebird was it. my brother has a 92 formula and we would like to reprogram it but not sure how or where to get the stuff to do it.
Hi,
It was a '88. But it should work the same way with the ECM of the '92.
There are alot of information on http://www.thirdgen.org.
Josh, you've got mail. ;-)
Mat
