Hello everyone,
Just wanted to see if someone smarter then myself wouldn't mind donating a minuet of their time to take a look at my tune and see if you notice anything I may have missed or possibly messed up on.
I just added a few things on my '01 Camaro, I went from full bolt-ons to a set of Trickflow CNC'd 215cc heads and a custom grind 235/243* 62x/.62x" 112lsa cam and a ported 90mm fast intake so my tune was way off. I used what little bit I have learned about tuning as well as looking at my buddies tune as a guideline for my starter tune. I guess I did something right because it starts and catches idle. but going into gear will sometimes stall it and it hunts for idle coming off a rev. I went for a small drive and besides the response of the new found power (which was WOW :devil: ) it doesnt fill totally crisp. was told that might be due to the fast intake??
As extensive as this tune needs to be Im not confident I could get it done without a little help and guidance from you guys. I have a wideband, Im just not sure where to start. it seems like the couple of the guides I found have been deemed outdated info, so if someone wanted to help me out with the procedure it would be much appreciated.
Mods include:
TFS215 heads
235/243* 620x/.623" 112+4lsa cam
FAST 90mm intake stage 1 porting
TPIS 90mm TB
stock MAF (I know, I know)
pacesetter headers
TSP true duals
ASP pulley
YT rockers
built 4l60e
ProTorque 2,800 stall
Stock 3.23 gears
Also, anyone know where to start with all these DTC's im throwing? haha
[PCM] P0122 - Throttle Position (TP) Sensor Circuit Low Voltage (Pending) (Immature)
[PCM] P0300 - Engine Misfire Detected (SES) (Pending) (Old) (History) (Current) (Immature)
[PCM] P1122 - Throttle Position (TP) Sensor Circuit Intermittent Low Voltage (Pending) (History) (Immature)
[Brake] U1000 - Class 2 Communication Malfunction (History)
[Brake] C0237 - Rear Wheel Speed Signal Erratic (Current)
[Brake] C0240 - (Current)
[Restraints] U1000 - Class 2 Communication Malfunction (History) (Immature)
[Restraints] U1016 - Loss of Class 2 Communication with VCM (History) (Immature)
[Restraints] U1096 - Loss of Communications with IPC (History) (Immature)
I just went from full bolt-ons to a set of TFS215's and a custom grind 235/243* 62x/.62x" 112lsa and a ported 90mm fast so my tune was way off. I used what little bit I have learned about tuning as well as looking at my buddies tune as a guideline for my starter tune. I guess I did something right because it starts and catches idle. but going into gear will stall it out and it hunts for idle coming off a small rev. I went for a small drive and besides the response of the new found power (which was WOW :devil: ) it doesnt fill totally crisp.
Mods include:
TFS215 heads
TPIS 90mm TB
30# SVO Red top injectors
pacesetter headers
TSP true duals
ASP pulley
YT rockers
built 4l60e
Stock 3.23 gears
Heres the tune im on and an idle scan as it was warming up as well a drive scan.
Thanks again
