Results 1 to 7 of 7
Thread: Tuning update now running on CORN
    I've chaned my methods a bit, instead of playing with the injector flowrates, and RPM tables, I've just started recurving the MAF, and it works great. Also by increasing timing, and leaning it out, I managed to get 28mpg out if it, keep in mind thats without any o2 sensors.
    My question is I've had some trouble with the timing, under boost, I discover that I can get rid of the knock by running the A/F at around 10.5:1, the problem is my ignition can't keep it lit at high rpm with that A/F, If I run it at 11.5-12 the knock comes back, and it still missfires, but not as much. Is its possible that I have folued plugs, or is this a common thing? Do you guys think better coils would help out? Is it possible the computer is seeing detonation, and calling it a missfire?
    http://www.cardomain.com/id/phoenix64
    99 3.8L camaro, corn fuel, turbocharged.
    98 formula LS6, lid, SLP DD, 65lb inj.
    Re: Tuning update and more questions.
    Geez, well I guess I'll continue talking to my self, just in case.
    Well the car is now running on a blend of corn alcohol, which has solved some of my problems, and introduced some new ones, details are over on FV6.com.
    Mar 2004
    Germantown, MD
    362
    Re: Tuning update now running on CORN
    ??? ok..
    -Bill
    2000 Camaro V6 Boltons and a tune
    I know some GTP guys are on this forum, do you guys know the difference between the L36 and L67 coils? I'm thiniking about swapping to a set to see if it helps the ignition.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,265
    Quote Originally Posted by phoenix64
    personally i dont know...you could probably ask some of the guys over at clubgp.com they might know ???
    Mar 2004
    Germantown, MD
    362
    tehy are probably exactly the same.. if a gtp guy had the PN for their coil packs I would look it up an tell you..
    but i am 90% sure they are the same..
    -Bill
    Thats the reason I asked, they don't have the same part number.
Similar Threads
  1. Correct Tuning Procedures
    By Jax5.7 in forum GM V8 Tuning - Engine, Gas (Gen 3)
    Last Post: 05-12-2022, 11:51 AM
  2. Your Guide to a good tuning experience
    By Bill@HPTuners in forum VCM Suite General
    Last Post: 10-27-2010, 11:59 AM
  3. E38 ECM Tuning update?
    By brianw21 in forum GM V8 Tuning - Engine, Gas (Gen 4)
    Last Post: 05-03-2007, 01:22 AM
  4. Base Running Airflow tuning ?
    By orange ss in forum GM V8 Tuning - Engine, Gas (Gen 3)
    Last Post: 04-23-2007, 03:04 PM
  5. VE tuning. Why won't my LTFT's or STFT's update?
    By V-10_Killer in forum GM V8 Tuning - Engine, Gas (Gen 3)
    Last Post: 04-27-2005, 02:55 PM
